ᐅ Building a wall: how much is 7 cubic meters...?
Created on: 14 Oct 2014 08:53
blockhauspower
Mixing 7 cubic meters of concrete is quite a challenge. I would order ready-mixed concrete delivered by truck. With a few helpers, wheelbarrow unloading is also possible, but it comes with an additional cost. Otherwise, just use a standard concrete mix recipe, which you can easily find online.
HilfeHilfe
14 Oct 2014 11:16
toxicmolotow schrieb:
Is the rule of three already too difficult? When is it taught? 4th grade? 5th grade? It used to be called word problems.
Necessary information can be found on every bag of cement or online.
That’s very kind of you. Bulk density and all that stuff were not covered in 4th or 5th grade.
Musketier14 Oct 2014 12:14
The original poster realized that they need to convert one unit into another. The concept of bulk density is irrelevant for solving the problem. There is a factor that needs to be applied (multiplication), and that’s it.
In Step 1, the density of concrete is needed. Step 2 then involves using a rule of three to calculate the actual amount of each ingredient.
Copy and paste from a website:
"You can find the density of concrete in standard reference books or online tables. Depending on the composition, the value for concrete is d = 2.1 - 2.6 t/m³ (2.1 - 2.6 tons per cubic meter). For calculation purposes, an average value of d = 2.4 t/m³ = 2400 kg/m³ (149.9 lb/ft³) is suitable, which should be safe for most applications."
No guarantee is given by me regarding accuracy.
Saruss
14 Oct 2014 13:54
That means 7 cubic meters (cbm) equals 16.8 tons of concrete. According to Bauexperte’s mix ratio, that’s 1,527 kilograms (liters) of water, 3,054 kilograms of cement, and 12,218 kilograms of gravel.
A few kilos won’t get you very far. I wouldn’t want to mix these quantities myself either—just think about how many times you’d have to run a small concrete mixer to reach that amount. A delivery is probably more practical...
toxicmolotof
14 Oct 2014 14:38
The cost for 1 cubic meter of ready-mix concrete is approximately 90–140 euros, depending on the type and chemical additives of the concrete. Just last week, I needed C25/30 for 95 euros plus VAT.
I definitely wouldn’t want to mix it by hand for that price.
blockhauspower14 Oct 2014 16:46
Then try getting 12,218 kg (26,925 lbs) of gravel from the building materials supplier—they will want to know the volume, that is, the cubic meters (cbm). For that, the bulk density is required.
toxicmolotof
14 Oct 2014 16:52
The building materials supplier can handle that by simply consulting their tables.
