ᐅ Self-Building a Staircase
Created on: 12 Feb 2017 17:32
Roppo
We are currently trying to decide which staircase to choose and how to build it 😉
We don’t want the standard staircase from the general contractor made of beech wood. Instead, we prefer a solid staircase made of reinforced concrete or a similar solution, where only the tread surfaces are later covered with wooden steps. However, there should still be enough space under the staircase for a storage closet, so the area underneath must not be closed off with walls.
Since these types of staircases are usually more expensive than simple wooden ones, we want to save money by doing as much of the work ourselves as makes sense (by the way, the staircase is quarter-turn).
I’m not exactly inexperienced with DIY, but I have absolutely no experience in staircase construction. Therefore, I hope to gather some important information here that will help me get closer to a decision on the best approach for a staircase project like this.
Here are some questions that are currently on my mind:
Are there legal requirements for staircases that must be followed? (...please don’t just say “yes, it has to support two people walking up together,” etc.) Or is it up to everyone how they move from the ground floor to the upper floor?
Does it even make sense to build the staircase yourself, or is it, in terms of cost-benefit effort, better to have a reinforced concrete staircase installed and then customize or add to it according to your wishes?
Please share your experiences and ideas on how to approach a staircase like this, without simply saying, “I’ll order the whole thing ready-made no matter the cost…”
As mentioned, we’re looking for the solution with the best cost-benefit ratio.
Thank you very much!
Ralf
Iktinos
14 Feb 2017 00:01
Roppo schrieb:
... and that would then be something you can definitely tackle, I think 🙂
For sure the surface; it’s fiddly work, but doable. The railing—whether masonry or any other type—you should buy separately. Both are fall protection measures and should be handled by professionals!
