ᐅ Building a Prefabricated House on an Existing Basement – Any Experiences?
Created on: 24 Oct 2018 22:32
Riiiiicki
I’d like to get your opinion on a topic—maybe someone has dealt with this before.
We have purchased a plot with an existing old building. The house is old and we don’t like it, so we want to demolish it.
However, the basement is still in great condition, so we’re considering keeping the basement and building the new house on top of it.
Does anyone have experience with this? What should we keep in mind? Do you think it’s worth it?
This would also save us the site development costs as well as the demolition of the basement.
We haven’t consulted an architect yet; that will be the next step.
Thanks a lot for your feedback!
We often see new houses built on old basements here. This applies to both solid construction houses and timber frame houses. Some build the new house to the same size as the basement, some smaller, some larger. In principle, this is possible. In all cases I know, the basement is only accessible from outside, not heated, and therefore only used as storage space that is not completely free of moisture.
I cannot comment on the costs, but overall it probably does not save much compared to a complete demolition.
Riiiiicki25 Oct 2018 22:35Thank you all very much, this already helps a lot!!!
Phew, we were actually expecting some savings since we wouldn’t have development fees/backfilling of the basement/etc. as cost items. We also thought that the demolition/"deconstruction" would be cheaper in the end?!
It doesn’t have to be a prefabricated house. We are still at the very beginning, and originally we didn’t want a basement at all, since the land costs were already so high, and now we’re looking at what is really necessary. But having a basement in general is of course great.
We are still at the very beginning, everything is open, and we are collecting ideas and experiences first.
The house’s floor area should definitely be larger, meaning the house would not be fully basemented in the end but about 3 m (10 feet) longer. We were told that this is not a problem and that it would be possible to work with a slab foundation.
The question is also who can even do this. We don’t have a construction company yet (as I said, we just met with the notary this week).
Most likely, we should ask an architect or structural engineer. I had hoped someone here might share their experience.
But apparently, it’s not even that common to actually use the basement....
By the way, the basement itself is excellent; an architect already confirmed to us that everything is very dry. The walls/floors would just need to be redone, it is heated and recently received new windows. So these costs are probably manageable.
Riiiiicki schrieb:
The walls and floors just need to be redone, it’s heated and recently got new windows. So these costs should be manageable.However, it probably wouldn’t meet current energy-saving regulations. But that’s not necessarily required. The basement is frost-free, the structural integrity would need to be checked, and a builder must be found who will build on the existing basement. Personally, I see the only issue being that the existing walls are load-bearing for the entire house. Because of this, the floor plan cannot be freely changed. But maybe everything can be adjusted somehow – a house is a house is a house.
See you then in the floor plan discussion.
Riiiiicki schrieb:
Thank you all very much, that already helps!!! No, that can’t really help because the basis for speculation is missing: let pictures speak more than a thousand words, then the crystal ball will clear up.
Riiiiicki26 Oct 2018 22:45I still need to take the photos again, as I don’t have them available right now. They will follow later....
