ᐅ Cleaning Shelf Brackets with Adhesive Residue – What Works?
Created on: 21 Aug 2022 10:12
Bejebla
Hello everyone, I recently assembled a Billy bookshelf and noticed some adhesive residues that are difficult to remove in certain areas. My specific question is: What methods or products work best to safely and effectively remove these adhesive residues without damaging the veneer or surface of the Billy bookshelf? I would appreciate recommendations that are effective on both fresh and dried adhesive, and tips that can be easily applied in everyday situations. Thank you in advance!
derrick34
21 Aug 2022 14:55
Siflo schrieb:
Many aggressive solvents can damage the veneer.
That’s exactly the point. Always test carefully first. If you want to take the risk, nail polish removers containing acetone are a no-go. They usually ruin the surface.
edisonbla
21 Aug 2022 17:18
I once had some glue residue on my Billy shelf and tried using a soft eraser – sounds strange, but it actually worked surprisingly well 🙂 No chemicals, no stains. Just rub gently and bit by bit until the glue is gone. Maybe this could be an idea for you if you prefer a mechanical method.
SUBEN60
22 Aug 2022 09:34
After thorough research, I recommend using a specialized wood adhesive remover designed for veneered surfaces when dealing with older or stubborn adhesive residues. Products like "Pattex adhesive remover for furniture" are available on most DIY retail websites and contain ingredients that dissolve the adhesive without damaging the wood. Important: Before use, test the product on a hidden area to ensure compatibility.
BOLUKEO
22 Aug 2022 10:12
Bejebla schrieb:
Is there a specific type of adhesive remover you would recommend especially for the thin veneer of the Billy bookshelf?
I would first suggest trying a mechanical approach, such as carefully scraping with a plastic scraper or an old credit card. If that doesn’t work, you can try a mild solvent like isopropanol, as already mentioned.
