ᐅ Ikea Besta – which adhesive is suitable for small repairs?
Created on: 3 Aug 2016 09:12
Tugannon
Hello everyone, some time ago I bought an Ikea Besta furniture combination, and unfortunately, some of the joints have become quite loose, with small cracks appearing in the material. For minor repairs, especially re-gluing connection strips and small broken areas, I would like to know: which adhesive is best suited for these small repairs on Ikea Besta furniture without damaging the material due to the glue’s effect or excessive pressure? It is especially important to me that the glue dries reliably, preferably transparent, and is suitable for wood-based materials or laminated surfaces. Has anyone had practical experience with this or can recommend something professionals use? Thanks in advance for your tips!
blapau
3 Aug 2016 12:25
Brief and practical for everyday use: wood glue is usually the first choice. For application, I recommend using a fine nozzle or a toothpick to precisely place the adhesive into gaps or small cracks. It is important to press the joint firmly together and immediately remove any excess glue.
For clearly visible repairs, once the glue has dried, you can gently smooth the area with fine sandpaper to ensure no white glue residues remain visible.
If the surface is covered with laminate but needs repair, a specialized laminate adhesive can also be used. However, this is not necessary if the damage is mainly in the particleboard underneath.
SETHBLA
3 Aug 2016 12:31
Wood glue + clamp, not too much applied, press firmly, done.
Tugannon
3 Aug 2016 13:06
Laukau5 schrieb:
If you provide more details about exactly where and what kind of damage there is, the recommendation can be made even more precise.
Thank you for the detailed feedback! The damage is mainly on the connecting trim strips, those small edge trims; in some places, they are slightly cracked at the corners or have started to lift slightly from the cabinet body. The surfaces themselves are stable, it’s just at the edges where the laminate/foil is peeling off a little bit in spots. That’s why I’m particularly looking for an adhesive that reliably bonds the strips again and isn’t too moist or aggressive to avoid damaging the material.
naudan schrieb:
If you like, please also describe whether the surface is matte or glossy, that helps with the assessment.
The surface is rather matte and feels slightly rough; it is definitely not high gloss. I hope that helps!
Laukau5
3 Aug 2016 13:23
Tugannon schrieb:
The damage is mainly on the connecting strips, those small edge trims; some are slightly cracked at the corners or have started to detach a little from the main body.
In that case, I would definitely use wood glue suitable for photovoltaic systems, because it penetrates well into fine gaps and becomes very strong once dried. Additionally, it does not react with the laminate film.
Tugannon schrieb:
The surface is rather matte and feels a bit rough
Careful sanding is definitely possible here, especially when cleaning and preparing the glued area, as a slightly roughened surface provides better adhesion for the glue.
It’s best to glue, as mentioned, under light pressure (possibly with small clamps or G-clamps) and then let it dry for at least 12 to 24 hours.
Very important: don’t apply the glue too thickly, otherwise it can dry with an unpleasant appearance and cause white spots on the surface.
Franz
3 Aug 2016 14:05
Laukau5 schrieb:
In that case, I would definitely use wood glue suitable for photovoltaic installations, as it penetrates well into small gaps and becomes very strong after drying.
I can confirm exactly that. I once had a similar repair on a Besta shelf, and with wood glue and good pressing, it held up perfectly. One more tip: if you're concerned about the appearance, you can carefully remove any glue residue after drying with fine sandpaper.
blapau
4 Aug 2016 09:48
In addition to the previous recommendations: If the edge strips already appear slightly worn or cracked, it can be helpful to apply a thin layer of clear varnish or wood glue to the surface with a fine brush beforehand. This increases the durability of the surface and usually prevents moisture from penetrating.
Regarding adhesives, I stick with D3 wood glue, which is waterproof and holds up well under higher stress. I strongly advise against using contact adhesives or all-purpose glues, as these could damage the surface.
