ᐅ Basement Flooring on Concrete Slab
Created on: 22 Mar 2015 18:37
schmemplkelmi
schmemplkelmi
22 Mar 2015 18:37
my basement currently has a concrete floor, which is always dirty and sandy... I want to change that now! I would appreciate suggestions for the right floor covering. A few details: the basement room is about 25 sqm (270 sq ft) in size, hardly or not at all damp, and the new floor covering can be a maximum of 1.8 cm (0.7 inches) thick. If possible, I would prefer not to install tiles...?!
Looking forward to some great tips
Luka
Dindin
22 Mar 2015 19:37
Honestly, I personally think tiles work best in the basement.
We initially installed laminate flooring in the basement hallway because the basement hallway is open and visible, and we found that nicer.
Well, then we had a water damage incident and the laminate was ruined, so we tiled instead, which we still consider the best decision.
I believe the concrete could also be specially treated.
schmemplkelmi
26 Mar 2015 10:17
Hello
Thanks first of all for the reply. The water issue wouldn’t be a problem since there have been no pipes in this area, and this room has been dry for 20 years. If you hadn’t had any water damage, would you have been satisfied with laminate flooring?
Thanks and regards
Luka
Dindin
26 Mar 2015 10:23
Even without the water damage, laminate flooring was not the ideal solution for our basement.
Since we have an unheated basement and the hallway, which is open to the upper floors, experiences temperature fluctuations, the laminate warps.
I believe this issue would not occur, or would be much less significant, in a heated basement. However, I would not install laminate in an unheated basement.
schmemplkelmi
26 Mar 2015 10:33
*thinking*
I just don’t want to “commit” right now. The tiles are not a solution for me, even though I understand all their advantages; maybe I will come up with some other alternatives. Thanks, and I’ll share more once I’m ready.
Regards,
Luka
nordanney
26 Mar 2015 10:40
What speaks against tiles from your point of view? What do you want to do in the basement?
