ᐅ Are there any assembly methods that can make the Ikea Brimnes more stable?
Created on: 6 Oct 2024 08:23
janoslis
janoslis
6 Oct 2024 08:23
Hello everyone, I have a question that hopefully someone in the forum can answer: Are there any assembly methods or techniques that can make the Ikea Brimnes furniture more stable? I find it visually practical, but when I load it more heavily or move it multiple times, it feels somewhat unstable overall. I’m not only interested in the usual assembly tips but rather advice on reinforcing the structure – for example, additional screws, connections, or other modifications that provide lasting stability. If anyone has experience or well-founded recommendations, I would appreciate detailed answers.
nubar
6 Oct 2024 09:17
I find this question very relevant because the Brimnes often starts to wobble under load in its standard condition. My recommendation is to pay special attention to the screws at the connection points of the side panels during assembly: I installed small metal brackets at the points where the back panel is screwed to the sides. These brackets noticeably increase stability, especially when the furniture is more heavily loaded. Additionally, using a back panel made of thicker material than the original board can help. Adding glue at the connection points is also a good idea if you want a long-lasting result.
Dilen
7 Oct 2024 14:52
Regarding improving stability in Brimnes furniture, I want to add some points based on my own experience and research from a few months ago:
- First, it’s important to understand the types of connections used. Brimnes often uses flat dowels and Minifix connectors, which are easy to assemble but can flex and lose some stability under load.
- One step I took was replacing the back panel: instead of the thin MDF sheet, I cut and installed a 5 mm (0.2 inch) multiplex board (birch plywood). This plywood was fixed on the inside with screws—not just stapled, as is common in many products.
- I also added small angle brackets inside the lower and upper corners, which are often missing in furniture. This helps prevent warping during use.
- Then, I used wooden dowels at the carcass corners instead of relying on Minifix screws alone—this stronger connection provided additional support.
- For added peace of mind: once the back panel is securely installed and the carcass properly fixed, it’s also worth gluing the edge battens.
One question for you: which loads and positions are particularly problematic for your furniture? Is it visibly wobbling due to uneven floors, or is the issue caused by the construction itself?
nolan
7 Oct 2024 19:34
Dilen schrieb:
One more question for you: Which loads and elements are particularly problematic in your case?
A simple and effective method is to additionally secure the furniture to the wall, especially for tall Brimnes models. This greatly reduces the risk of tipping and increases stability. Alternatively, wood or metal brackets can be used at the joints, but wall mounting has the greatest impact.
Lorukeo
8 Oct 2024 07:08
In addition to the previous recommendations, I would like to add the following systematic points to stabilize the Ikea Brimnes:
- Reinforce the corner joints with metal brackets or strengthened wood connectors (e.g., biscuits or custom-fit dowels).
- Replace the thin back panel with a stronger material, preferably plywood or OSB boards, attached with screws at the fixing points.
- Use wood glue at all joints, especially at glued connections, whose curing significantly improves stability.
- Add extra support beams or cross braces on the back, if the interior space allows.
- For instability near the floor: check the flatness of the subfloor and, if necessary, install adjustable feet for leveling.
These measures combined have a measurable impact on the overall stability and prevent damage from shear forces during loading or moving. It is important that changes remain reversible in case the furniture needs to be relocated.
