ᐅ Air-to-Water Heat Pump Operating in Heating Mode – Is This Heating System Vulnerable?
Created on: 20 Oct 2017 14:59
TentakelHello, we received an additional quote from our heating installer to carry out the heating program for the underfloor heating and screed drying using a mobile 20 kW electric heater. Apparently, the air-to-water heat pump cannot do this because it only has an 8 kW output, and if it did work, something would probably get damaged. Of course, I would like to avoid these extra costs and believe that a short-term flow temperature of 45°C (113°F) should be possible with an air-to-water heat pump.
Have you done the functional heating with an air-to-water heat pump? Is the heater in the air-to-water heat pump really that sensitive?
Thanks!
Thanks!
Nonsense. Of course, it is possible. But under certain circumstances, it might not even be feasible.
Why wouldn’t the heat pump be able to deliver 45°C (113°F) supply temperature at +10°C (50°F) outside?
Sure, it becomes inefficient, but that doesn’t really matter for a short period.
If the heat pump can’t reach 45°C (113°F) supply temperature at +10°C (50°F), then it won’t manage 25°C (77°F) supply temperature at -10°C (14°F). And that’s rather unlikely.
