ᐅ After staying unused for a long time, the Kallax is stuck to the wall – how can I clean it?
Created on: 20 Oct 2021 18:37
kaustepan
kaustepan
20 Oct 2021 18:37
I have an Ikea Kallax shelf unit that I left unused against the wall for a long time due to rearranging. Now I’ve noticed that it seems to be practically “stuck” to the wall, meaning it’s very difficult to pull away without damaging either the wall or the shelf. My guess is that moisture or slight adhesive residues from the wall paint or wallpaper are responsible after standing there for so long. Does anyone have experience with how to best and gently remove this kind of sticking?
Of course, I don’t want the paint or wallpaper to peel off the wall later, nor do I want to damage the shelf’s edge surface. What cleaning agents or solvents would be suitable? Or are there any physical methods to carefully free the shelf without applying too much force?
I would really appreciate any tips and advice!
GIPAPO
20 Oct 2021 19:08
first try using a hairdryer to slightly soften the stickiness with heat. Then carefully use a plastic scraper to pry between the shelf and the wall. If any residue remains, use some mild dish soap with water and a soft cloth. Avoid harsh solvents, as they could damage the surface.
BENBI
21 Oct 2021 08:22
Hello kaustepan,
I completely understand what you mean by “sticking” – such bonds often form due to the interaction of moisture, pressure, and certain substances in wallpaper adhesive or wall paint that bond with the Kallax unit. To address the issue thoroughly, I would recommend the following approach:
1. First, try to loosen mechanically: As already suggested, applying heat with a hairdryer is a good start, as many adhesives or residues soften this way.
2. Insert a thin plastic putty knife or even a sturdy plastic strip between the shelf and the wall, then gently pry it apart. Important: Do not use a metal scraper, as this could cause permanent damage to the surface of the Kallax.
3. Clean the residues: I recommend a mixture of lukewarm water and a few drops of mild dish soap applied to a soft microfiber cloth. This will help to dissolve remnants caused by dried adhesive. However, test the solution first in an inconspicuous area to avoid discoloration.
4. If this is not enough, it gets tricky: Since some wall paints or wallpaper adhesives are water-soluble, applying moisture with a sponge can help loosen the bond between the shelf and the wall. But be careful: too much moisture may damage the wall paint, so always use only lightly damp cloths and avoid soaking.
I would also be interested in some details: Did the shelf stand directly on wallpaper or on a painted surface? Are there visible residues? Depending on the situation, solvents like isopropanol could be tried, but only with caution and always tested first in a hidden spot.
Feel free to ask if you have any questions!
nedagla
21 Oct 2021 11:45
GIPAPO schrieb:
try using a hairdryer first to soften the stickiness with some heat.
That’s exactly what I wanted to suggest! Heat often surprisingly loosens stubborn adhesive spots :-)
And: patience really is half the battle here! It’s better to try lifting gently and apply heat as needed, rather than being too rough and damaging the nice finish.
Maybe one more tip: a bit of baking soda can help with stubborn glue if it’s gently made into a paste. The powder acts as a mild abrasive and can help remove the adhesive residues—but test carefully here too.
Good luck, and keep us updated on how it goes!
SUDAN
22 Oct 2021 09:03
Hello kaustepan,
I would like to address your question in more detail and offer you a structured approach to safely remove your Kallax from the wall without causing damage to either side:
1. Preparation:
- Clear enough space around the shelving unit.
- Gather the necessary tools: a hairdryer, a soft plastic scraper, microfiber cloths, mild dish soap, and possibly small amounts of isopropyl alcohol (cleaning alcohol).
2. Steps to follow:
- Gently warm the shelving unit on the wall side with the hairdryer, making sure it doesn’t get too hot (maximum 40-50°C (104-122°F)).
- Carefully try to slide the plastic scraper between the shelf and the wall to lift the unit.
- If the shelf is only stuck in certain spots, you can use a warm, damp cloth on the wall side to help soften the adhesive. Be careful not to damage the wood or paint with moisture!
3. Cleaning:
- After removal, check for any residue on the shelf. Usually, a damp microfiber cloth with a little mild dish soap will help.
- Light water-soluble adhesive residues can be removed this way.
- If that is not enough, you may attempt gentle cleaning using a small amount of isopropyl alcohol—always test this first in an inconspicuous area!
4. When to stop:
- Stop immediately if you notice the material dissolving, scraping, or peeling.
Common mistakes:
- Using too much moisture, causing swelling of the shelf or damage to the wall surface
- Applying excessive force when removing, which can lead to damage
If you can provide more details about the wall surface, for example, smooth paint or textured wallpaper, that would be very helpful. Sometimes different methods are needed depending on the substrate.
I hope this guide helps you. 🙂
