ᐅ Neighbor plans to build a semi-detached house with a staggered layout
Created on: 1 Jul 2025 15:55
m0LN4rius
We are building a semi-detached house directly on the property boundary. Our neighbor now wants to build later with an offset of more than 1–2 meters (3–6 feet) from us – meaning not directly adjoining. In conversation, we had the impression that he is not fully aware of the construction-related consequences of this decision. We have already completed planning and obtained the building permit / planning permission, and we want to start soon.
We wonder how to kindly point out that this gap will cause significant additional risks and costs—for example:
- He will need a separate fire wall and is not allowed to extend insulation, plaster, or roof components beyond the property boundary.
- The insulation of his boundary wall must still be fully installed and permanently protected, which will be difficult without an overhang or sufficient working space.
- The gap that arises must remain sealed, accessible, and maintainable—otherwise, issues such as moisture, debris, and frost damage may occur.
- Base, roof, and metal flashing work will become more complicated and expensive on both sides.
- Our kitchen exhaust is located on that side, and we want to avoid problems with condensate or heat radiation affecting his wall.
- Overall, the offset creates costs that could be avoided with a direct adjoining build, considering regulations like the Building Energy Act, BayBo, and others.
What is the best way to approach this topic without giving the impression that we want to interfere? We simply want to avoid future disputes and clarify who is liable for what if he chooses this solution.
nordanney schrieb:
So, the first question: Is he even allowed to do that, or is only a semi-detached house permitted on the plot? Definition of semi-detached house in the land use ordinance. If absolutely required according to the development plan / building permit plan, then the issue is settled.The option E/D in the development plan narrows down to D as soon as the first D at the shared boundary has been applied for building permission.https://www.instagram.com/11antgmxde/
I understand it already means "staggered," otherwise it wouldn’t be called a semi-detached house.
And also here:
The original poster is then threatening the same on the opposite section.
However, insulation can be installed across the boundary; I just don’t know if this rule only applies to subsequent renovations.
Ultimately, regarding the question:
Just ask how they imagine the side insulation: whether they would accept your insulation. Then they might realize the disadvantages, if their architect has not already told them.
And also here:
m0LN4rius schrieb:This will refer to the offset side, which would not exist without the stagger.
requires a separate firewall and no insulation, plaster, or roof components crossing the boundary.
m0LN4rius1 Jul 2025 19:0011ant schrieb:
I’m thinking more about complying with the extension obligation, but with an underbite/overbite on the municipality side.
Also, professionals place a ventilation shaft on an “undivided own” exterior side. The exhaust duct is marked in red and will meet moisture on a cold wall about 40cm (16 inches) from its wall; the kitchen floor plan is final and cannot be changed.
The 1–2 m (3–6 ft) offset must then be plastered and insulated on both sides; he wants to plan the insulation on our property side.
For the kitchen, I don’t mind (the terrace is on the side), but plastering was not planned on our side, nor according to the development plan.
Below is the development plan:
m0LN4rius1 Jul 2025 19:04ypg schrieb:
I understand it as “staggered,” otherwise it wouldn't be called a semi-detached house at all.
And also in this case:
This will relate to the extended side, which wouldn’t exist without the offset.
The original poster is facing the same issue on the opposite part.
However, thermal insulation is allowed to extend beyond the boundary, although I’m not sure if this rule only applies to renovations.
Just ask how they envision the side insulation—whether they would accept your insulation. They might then see the disadvantages, assuming the architect hasn’t already told them. The lender views this critically because the mortgage lien is on the property, and foreign elements would then be on the land. The bank will definitely not agree to this, and neither will we.
m0LN4rius1 Jul 2025 19:07Oh, and the plot needs to be raised by 1.5 m (5 feet), and where the offset would be, the foundation plinth has to be constructed differently.
nordanney1 Jul 2025 19:19m0LN4rius schrieb:
He wants to plan the insulation on our property side.He has no right to do that. In Bavaria, this is only allowed on existing walls (old buildings). But you don’t have the right on his side either. m0LN4rius schrieb:
The lender sees this as critical,No, they don’t (I’m a lender myself). But since he’s not allowed to do it, the issue will resolve itself. m0LN4rius schrieb:
The exhaust shaft is marked in red; about 40cm (16 inches) from his wall, moisture will meet a cold wall,That wouldn’t be your problem and this is quite common in these types of buildings. Otherwise, offset construction is nothing unusual (just more complex and expensive).
Please provide some information about the development plan. Name and city. What is stated in the textual requirements?
