ᐅ Neighbor plans to build a semi-detached house with a staggered layout
Created on: 1 Jul 2025 15:55
m0LN4rius
We are building a semi-detached house directly on the property boundary. Our neighbor now wants to build later with an offset of more than 1–2 meters (3–6 feet) from us – meaning not directly adjoining. In conversation, we had the impression that he is not fully aware of the construction-related consequences of this decision. We have already completed planning and obtained the building permit / planning permission, and we want to start soon.
We wonder how to kindly point out that this gap will cause significant additional risks and costs—for example:
- He will need a separate fire wall and is not allowed to extend insulation, plaster, or roof components beyond the property boundary.
- The insulation of his boundary wall must still be fully installed and permanently protected, which will be difficult without an overhang or sufficient working space.
- The gap that arises must remain sealed, accessible, and maintainable—otherwise, issues such as moisture, debris, and frost damage may occur.
- Base, roof, and metal flashing work will become more complicated and expensive on both sides.
- Our kitchen exhaust is located on that side, and we want to avoid problems with condensate or heat radiation affecting his wall.
- Overall, the offset creates costs that could be avoided with a direct adjoining build, considering regulations like the Building Energy Act, BayBo, and others.
What is the best way to approach this topic without giving the impression that we want to interfere? We simply want to avoid future disputes and clarify who is liable for what if he chooses this solution.
m0LN4rius2 Jul 2025 20:49Well, it’s a matter of perspective. Over the past 2-3 years, we have looked at numerous 40-year-old houses; none of them were intact, and all had mold issues in the corners.
m0LN4rius schrieb:
Yes, it will just be much more expensive for both of us, and I suspect that our corner wall at the back will then need a retaining wall or a strip foundation about 2 meters (6.5 feet) deep. This is the lowest spot, down to street level, with about 1.5 meters (5 feet) of topsoil removed, give or take. So, you want to build without a basement as first-time builders, even though that means ignoring the terrain, and your house corner requires underpinning. You don’t know whether he plans to build with or without a basement, but you consider his intended setback to make the situation with your unsupported floor slab corner worse?
It seems to me there is more going wrong here than just him not openly sharing his real motivation and you not asking about it. For an outsider, it’s hard to tell who is burying their head deeper in the sand — the most important thing is that you consider your kitchen design final, even though many questions remain unanswered.
If I were king of Germany, I would ban uncoordinated construction of semi-detached houses and introduce mandatory intelligence tests for both property owners on the shared boundary.
m0LN4rius3 Jul 2025 08:20All plots must be filled to the same level 😉 including the corners.
He is not building a basement because currently, the prices here start at 100,000, as we have asked.
m0LN4rius schrieb:
He is not building a basement, as the prices here currently start at 100,000 (approximately 110,000) — we inquired. Here we have someone again who hasn’t read the 11ant basement rule: a basement doesn’t cost its full price, but rather the difference between its price and that of alternative ground adjustments. He probably also hasn’t taken into account the costs of underpinning on his calculations. I stand by my point: you both should reconsider the plans and then lay the foundations at the same time.
m0LN4rius3 Jul 2025 14:21A simple basement then results in a difference of 60,000 to 70,000.
m0LN4rius schrieb:
A basic basement then comes to a difference of 60,000–70,000 (currency not specified) And that doesn’t yet deduct the rooms that can be built there.https://www.instagram.com/11antgmxde/
