ᐅ Experience with Shelly Pro Series vs. Homematic IP Wired vs. Bus Wiring Systems
Created on: 24 May 2022 14:58
Stravanzer
Currently, our shell construction is completed, and soon the electrician will start the rough installation.
We already had a few appointments beforehand where a “smart home” package was offered to me.
The electrician commissioned by the developer offered a complete KNX automation system for a “small additional cost” of about €15,000 (around $16,200).
This included the Gira X1 system with server, switches, wiring, documentation, etc.
The high price discouraged me, so I decided to go with the conventional option.
My plan was/is to automate the following:
a) Operate and automate roller shutters/blinds using Shelly flush-mounted actuators, possibly also controlled by a weather station
b) Control some sockets (especially in our child’s room) using Shelly devices with timed on/off switching
c) Manage lighting through Philips Hue
I am still not completely happy with my decision for conventional wiring.
It bothers me that I have different manufacturers involved, which makes central administration rather unlikely, at least as far as I know. (Is there a way to centralize control for my purposes? If yes, please let me know 🙂 )
Also, the automation would always run over Wi-Fi. I would much prefer a wired solution.
In this context, I looked into the Shelly Pro series.
This is basically the “wired” version, which should be enough for my modest requirements.
Has anyone here worked with these devices or, even better, installed them?
There are some YouTube videos, but mostly single examples, and not very conclusive.
I also really like the Homematic IP wired system. It would allow central control installed in the distribution board (DIN rail). However, here too, there are issues with the connection and required inspections.
The more I think about it, the more I consider having the electrician install bus wiring after all, while I set up the network and server infrastructure myself.
Wiring a patch panel and switch is not a problem for me.
However, I have some doubts about whether I have enough experience to connect the server myself.
Furthermore, there is the challenge of designing and programming the system and routines.
Basically, I am technically inclined and can read into certain things.
I wouldn’t shy away from it but am unsure whether I might be in over my head?!?
Besides, everything would have to be certified by a licensed electrician!
I told the electrician about my plan; he generally has no problem with it, but I would need to install the cables in the basement myself.
He said he wouldn’t connect any hardware he did not supply or install himself, for warranty and liability reasons.
My suspicion is that he makes less profit with this variant and that’s why he said this... and everything would still need approval anyway. Whether this will go smoothly... I have no idea.
For my part, I want everything properly certified, also because of insurance and similar concerns.
My question now:
Is a KNX-based bus solution “overkill” for what I want to do, or are WLAN Shelly devices sufficient to integrate performance data into the FritzBox?
An Ubiquiti PoE ceiling access point is planned/being installed on every floor. So, hopefully, Wi-Fi connection will be sufficient if I end up going with just the flush-mounted Shelly devices.
Maybe some of you have tips, suggestions, or ideas...
I would like to thank you in advance for a constructive discussion.
Tom
My question now:
Tom
nordanney schrieb:
You can do that, but it’s completely unnecessary and a waste of money for just a few gimmicks. Regular (inexpensive) Shellys are enough. If you know wireless technology, you go for wired. Having everything centralized in the distribution panel makes perfect sense to me as well.
I just find the Shelly app terrible, so it’s definitely worth considering an alternative visualization.
nordanney19 Nov 2024 13:57OWLer schrieb:
If it is indeed durable, that would be an advantage. I've been regularly replacing my 2.5 models with new 2PM ones for a few months now.I've never had a problem. Neither with the 1 nor the 2.5. No connection losses or defects at all.Araknis schrieb:
Anyone familiar with wireless chooses cable.Is that so? No issues with wireless—at least not for me.I have now installed 60 Shelly devices throughout the house, along with some other gadgets connected via WiFi. In addition, there is a small Zigbee network for a few lamps. Obviously, using just a Fritzbox and/or repeaters is not very effective. However, including a UniFi system (6 access points, various switches, etc.), I am still below the projected cost of systems like Loxone or KNX. Everyone has their own preferences—and can do it themselves(!)
sysrun80 schrieb:
I’ve installed around 60 Shelly devices in the house by now, plus some other gadgets connected via Wi-Fi. I also set up a small Zigbee network for a few lamps. Obviously, you can’t get very far with just a Fritzbox and/or some repeater setup. But even including the Unifi system (6 access points, various switches, etc.), I’m still below the projected cost for Loxone or KNX. Everyone has their own preference – and should be able to do it themselves(!) Do you happen to have any blinds as well?
