ᐅ Floor plan design for a single-family house, 165 sqm, without a basement, on a 400 sqm plot
Created on: 10 Aug 2023 09:33
Maulwurfbau
At the request of 11ant, here is a post with the completed list ;-) Unfortunately, he still doesn’t have a crystal ball.
Providing all information possible/available at this point in time.
Plot size: 400 sqm (4300 sq ft)
Slope: No, and no means no!
Floor space index (FSI): 0.4
Floor area ratio (FAR): ?
Building envelope, building line and boundary: Yes, available.
Edge development: Possible with garage.
Number of parking spaces: at least 1, preferably 2
Number of storeys: 1-2
Roof type: Gable roof (pitch minimum 31°, maximum 45°)
Architectural style: ??
Orientation: Gable end facing
Maximum heights / limits: Roof ridge 6-7 m (20-23 ft), eaves 9-12 m (30-39 ft)
Other requirements: No brick facades allowed. Driveway or space in front of garage at least 6 m (20 ft). Red roof tiles mandatory, light facade.
Homeowners’ Requirements
Architectural style, roof type, building type: Gable roof, fixed
Basement, storeys: 2 full storeys without basement
Number of occupants, age: 4 people (2 toddlers)
Space requirements on ground floor and upper floor:
Office: Family use or home office? Office of approx. 12 sqm (130 sq ft) is a must.
Guest bedrooms per year: Few
Open or closed architecture: ? Whatever that means.
Conservative or modern construction style: rather modern construction.
Open kitchen, cooking island: Open kitchen, possibly with cooking island
Number of dining seats: 6
Fireplace: NO
Music / stereo wall: Not planned, TV location is quite important.
Balcony, roof terrace: NO
Garage, carport: Garage desired. Carport with storage box also conceivable.
Utility garden, greenhouse: NO
Further wishes / special features / daily routine, preferably with reasons for choices:
Laundry room on the upper floor. They want to do laundry where it is generated and where it must be returned clean. Anything else is a hassle, at least for us.
Who designed the plan: Architect
Everything we provided as basic information and what our daily life requires has been implemented.
We like the clear lines/structure.
The open space in the hallway.
The connection/proximity of all rooms on ground and upper floors that need water/sewage. So no funny business with the bathroom upstairs in one corner and the utility room diagonally opposite on the ground floor. Personally, I like that.
No bay windows or other awkward extensions.
Laundry room upstairs where the washer and dryer are planned.
What don’t you like? Why?
The living room might be a bit too exposed for us. It could also be a cozy nook with TV without direct view of the kitchen. Cooking and eating together openly is liked; the living room could be a bit more separate. Currently, the floor plan shows it like a narrow, rather shadowy corner.
The somewhat narrow bedroom upstairs is not a dealbreaker but not 100% pleasing.
Personal price limit for the house, including fixtures and fittings:
500-575k
Preferred heating system:
Predefined, ground source heat pump with collector. Cold local heating network.
If you have to give up, which details/extras
-can you do without:
The small additional room for the father upstairs.
Garage, as mentioned carport also conceivable.
-can you not do without:
Office.
Storage box at garage or carport.
Children’s rooms.
The design turned out this way because the architect implemented our wishes and requirements almost 1:1. This preliminary layout resulted in this first version.
What do you consider particularly good or bad?
See what we like and what not. We don’t find anything particularly bad. Rather, not entirely optimal.
Position garage flush with house or set back?
43.5 sqm (468 sq ft) + 4 sqm (43 sq ft) pantry sufficient as “all-purpose room”?
Same floor plan possibly mirrored? Then office on south side, sun all day, blinds always down. Same issue upstairs with bedroom in summer at least. Entrance farther from parking space.
The building method will be timber frame construction with a local timber builder.
This is a first sketch after clarifying needs/wishes with the architect.
Fireplace: NO
500-575k
Office.
Children’s rooms.
Maulwurfbau16 May 2024 19:51K a t j a schrieb:
Not just those, if you ask me.
Yes, letting in light for example. Your windows remind me more of loopholes. This is going to be a bunker. Well, we find all the other facades quite successful and very harmonious. Obviously not symmetrical—that's a requirement for most people, to have things as symmetrical as possible. The new ones, we really like the other facades. We didn’t necessarily want the standard suburban new-build pitched roof house look.
Only the east facade feels a bit awkward to us. Partly because it serves five different rooms, each with a different function.
It will probably stay that way functionally, and the appearance will have to take a back seat. No idea. Capturing the continuous window band at the top wasn’t a good idea for the interior, that’s at least become clear now. Thanks for that.
I really don’t understand this window strip at all. If you have a height-adjustable workstation and sometimes work standing up, then you have a window at waist height and no view outside. When you enter the room… still nothing. Unfortunately, I don’t see any interior planning here.
Maulwurfbau16 May 2024 22:01Yes, that's correct. This is sloppy work. We will review it again. Thank you. The longer I look at it, the worse I think it is.
Maulwurfbau schrieb:
The feeling of space inside the room would be more important.You say that after stating that you can’t see outside from inside or that it feels like a basement inside. You notice that yourself, right? Maulwurfbau schrieb:
Sorry. Here is the floor plan.Thanks. I see the office… okay… I can tell you that the office window on the left has a transition compared to the window on the upper floor. Without checking your upper floor, I can’t tell you which window needs adjustment. This also applies to the entire upper floor row. So, if you are so kind, and want constructive ideas, please provide all the floors relevant to the facade. Maulwurfbau schrieb:
But there are a lot of smart alecks around here… Man, man man 🤨True! Without them, you won’t get any questions answered here.Maulwurfbau schrieb:
Well, we find all the other facades very successful and harmonious. Obviously not symmetrical, but most people tend to expect symmetry wherever possible. Anyway, we really like the other facades. We didn’t want the standard suburban new-build gable roof house look. Funny. I told him it would be too dark, and he kept going on about "symmetry." It’s too exhausting when you deliberately misunderstand. Good luck.
Maulwurfbau17 May 2024 07:52Funny. Nowhere did I read anything about it being too dark.
I assumed that having window areas between 15 and just over 20% of the room’s floor area would be sufficient. In almost every larger room, there are two windows to let in light from two different directions. It’s not supposed to be a glass palace. That was actually a trend in the 2000s as well.
Unfortunately, the rude tone in this forum is a trademark. Really a shame and somehow disappointing, since it’s actually a good thing overall.
Thanks as well, and I’m hoping for some good luck.
