ᐅ Water supply line for backflow replenishment and irrigation
Created on: 31 Aug 2022 15:41
DASI90
We have decided to install a pool and want an automatic water refill system as well. This means we need water supply in our outdoor storage area, where the pool equipment and irrigation control will be located. Of course, we didn’t consider this during planning and construction, as the desire for a pool and automatic irrigation came much later. Anyway.
The outdoor storage is part of the house but is outside the thermal envelope and has no direct access from the house. Now the question is how to get the water connection into the outdoor storage. We would definitely install a backflow preventer. There are basically two options:
1) The pool installer suggested running an additional cold water line from the utility room on the opposite side of the house into the outdoor storage. We could tap off from there. However, this would require a core drill through the concrete wall and insulation, which I would prefer to avoid. The pool installer says this would pose no problem if the drill hole is properly foamed/sealed afterwards. So neither thermal nor sound insulation should be affected, especially since the outdoor storage already has a door and is otherwise tight.
2) I’ve only recently considered this option. We already have a frost-free outdoor faucet at the front. Would it theoretically be possible to modify this faucet or run a line from it through the garden and the front, uninsulated wall of the outdoor storage to supply the equipment? Or is this not advisable or feasible for some reason? The missing outdoor faucet could potentially be replaced by a water outlet if this works out.
Technical floor plan: Outdoor storage, utility room, cold water line, pool equipment; frost-free outdoor faucet.
What do the experts say? Is the solution with the additional line harmless and cleaner? Or am I risking creating a hole that wouldn’t be necessary otherwise?
DASI9014 Oct 2022 16:03
Okay. But can I replace the insert? I have already looked through the Doyma site a bit, but I wasn’t really sure if there are other inserts available for our case, especially those with a hole in the middle for the brine and smaller openings.
rick201814 Oct 2022 16:14
The hole is then no longer centered but closer to the edge. You only need to know the diameters and the quantity. Nothing more.
You loosen the screws, which relaxes the rubber and prevents it from getting stuck in the drill hole.
DASI9014 Oct 2022 16:17
Ok. Thanks, I will discuss it again with the pool builder and installer to see if we can add another pipe there. In principle, it should be quite feasible, since the drilling is already fairly large.
rick201814 Oct 2022 16:43
The borehole is more than sufficient for running electrical wiring.
Costruttrice
14 Oct 2022 17:19
According to our drilling company, the brine pipe must be at least 70cm (27.5 inches) away from other utility lines.
DASI9014 Oct 2022 17:31
Costruttrice schrieb:
According to our drilling company, the brine pipe must be at least 70cm (28 inches) away from other utility lines.
Does this not refer to the inlet and outlet of the brine pipes to prevent the warm line from drawing heat away from the cold line?
