ᐅ House construction planning: realistic cost estimate for a semi-detached house?
Created on: 21 Jan 2022 12:51
sanny_La
We are planning to build a semi-detached house and currently don’t know what the neighbor intends to build.
We are thinking of about 150 square meters (1,615 square feet) and would like truly separate walls between the houses, as we want to be able to play the piano or vacuum in the middle of the night, roughly speaking. Are there special insulation options for walls between the units? We are also considering whether to go for a solid construction or a prefabricated building, as well as the level of finish, and whether doing some work ourselves with help from family and friends could save money...
Does anyone have a rough idea of the price range for something like this?
Benutzer200
21 Jan 2022 14:11
Crossy schrieb:
Outdoor Areas
Tip on pricing from the landscaper: 100€ per square meter of land. This includes the lawn, driveway, bushes/trees, beds with edging, lawn edging stones, lighting, terrace, etc.
Crossy
21 Jan 2022 15:15
Benutzer200 schrieb:
Tip for pricing from the landscaper: 100€ per square meter (10.8 sq ft) of land. This includes the lawn, driveway, bushes/trees, flower beds with edging, lawn edging stones, lighting, terrace, etc.
For smaller plots, this might be a reasonable guideline, but not for larger ones. That would mean spending 130,000€ on our outdoor areas. But it wasn’t that bad, despite a significant slope, terracing, L-shaped retaining walls, 3 terraces, lots of planting, driveway, outdoor stairs, lighting, and so on. However, I believe for an average-sized plot with complete landscaping from a garden landscaper, a ballpark figure between 40,000€ and 60,000€ is realistic. With a slope, costs can quickly be even higher.
Benutzer200
21 Jan 2022 15:44
Crossy schrieb:
For smaller plots, that might be a reasonable guideline, but not for larger ones. Then we would need 130,000 EUR for our landscaping.
A 1,300 sqm (14,000 sq ft) garden is no longer really "normal" either 😉. For standard building plots up to around 800 sqm (8,600 sq ft), meaning garden space of about 650 sqm (7,000 sq ft), it fits quite well. In that case, you wouldn’t be far off from your estimate. Although with 40,000 EUR I wouldn’t know how to manage a nice garden, driveway, terrace, etc. if you hire it done – an energy-efficient mortgage (EEM) helps a lot in that regard.
11ant21 Jan 2022 16:03
sanny_La schrieb:
We want to build a semi-detached house, but at the moment we don't know what the neighbor plans to build.
I already shared a lot of information with you about this basic issue elsewhere yesterday – now you have found your way to the forum where you can read through the examples of @goalkeeper (and also @MadameP). Additionally, using the forum search with the term "mortar blob" will lead you to several threads discussing soundproofing issues in terraced and semi-detached houses.
sanny_La schrieb:
and we want truly separate walls between the houses,
The keyword here is "party wall," which for some time now has not actually been a "shared" wall for both halves.
21 Jan 2022 17:53
You can find detailed discussions on this topic in the subforum Construction Costs
https://www.hausbau-forum.de/forums/baukosten-foerderungen.180/
This is where the planning forum is located..,
sanny_La schrieb:
real" separated walls
… every modern house has this. There is no need to worry about that.
sanny_La schrieb:
as well as the level of completion, whether we would also save money by doing some work ourselves with help from family and friends...
… usually, it is the incorrect DIY installations on the floors that cause problems, where the floating screed or floor covering ends up connected or in contact with the exterior wall, resulting in sound transmission through the wall.
Ali Gator
25 Jan 2022 13:49
We are currently building an extension onto our existing house, 140m2 (1,507 sq ft), with two full stories and no extras. According to the current plan, the costs are around 480,000€. Flooring, tiles, bathrooms, and the garden will be done by myself but are already included in the price. The actual pure construction costs, according to the contract, amount to 380,000€. However, there will be two separate residential units which we will rent out.
