Hello everyone!
I’ve often heard the saying, “Your first house is built for an enemy” — I wouldn’t put it quite that harshly, but after a year in a new build, I understand what they meant. 😀 Since we might move again, I’d like to collect some ideas here and benefit from your experiences: What would you do differently if you were to build again?
Here’s what I’ve noted so far:
What about you?
- electric roller shutters
- thermostats with displays
- larger storage room
- less awkwardly shaped rooms
- dedicated cloakroom area
- wooden window sills (?)
- more outdoor power outlets
- power outlets in window frames
What about you?
haydee schrieb:
Usually, it doesn’t bother me if my husband gets up earlier. Yes, that varies a lot. Some people are light sleepers, others sleep very deeply, and some go to bed after a late shift at 2 a.m., while those on the early shift have to get up again at 5 a.m.
Then you only grab one sock, still need the other one, or the weather forecast shows rain and doesn’t match the outfit you’ve laid out. Also, the blouse that the late-shift person left “outside” gets wrinkled. And to prevent these annoyances from becoming a never-ending story — like Groundhog Day every day — you move the wardrobe from being just a temporary storage to a separate room.
haydee schrieb:
Laundry goes straight to the wash. That’s why the utility room is on the sleeping floor. Not everything that’s been worn is actually dirty.
Yes, that's just the way it is. I have implemented half of the items listed in the first post in the house because I consider them essential in a modern home. For example, Silas, having power outlets in every corner inside and outside. Obviously, electric blinds everywhere and temperature displays in every room. In my view, this is basic standard. Also, LAN and satellite connections at least in the key rooms are a must.
However, I would also wish for a larger storage room.
kati1337 schrieb:
Hello everyone!
I’ve often heard the saying, "the first house you build is for an enemy" – I wouldn’t put it quite so harshly, but after a year in our new build, I understand what they meant. 😀
Since we might move again eventually, I want to collect some ideas here and learn from your experiences: What would you do DIFFERENTLY if you were to build again?
- rooms with less awkward layouts
- power outlets integrated into window frames
What about you? We’re currently building, but here’s what I would add to your list:
- electric roller shutters with a central switch, so you don’t have to run to each one separately.
This is never really a question or optional, for example. I consider it a given that if a house has roller shutters, they should naturally be controllable centrally from multiple points. We are not living in the Middle Ages.
The same obviously applies to lighting, alarm systems, power outlets, and other devices. Having both central and individual off control is simply a must if the system is electrically operated.
KingJulien schrieb:
Wood stove, basement, closed kitchen / living room Do you currently have a closed kitchen?
Open plan kitchens and living areas are really trendy right now. We have it like that too, and after about a year I still can’t say for sure how I would do it in the next house.
It’s nice when you have guests and someone is always working in the kitchen. You can see each other and everyone can chat.
But it’s annoying when you want to watch TV in the evening and someone has set the dishwasher to “eco” mode instead of silent mode.
Or while one person is cooking, the other can’t really watch TV well. On the other hand, that situation hasn’t happened very often so far.
What really annoys me is the lack of a counter or similar — I love the big island, but there’s always some dishes lying around somewhere, especially when the dishwasher is running.
Different wake-up and bed times don’t disturb the person sleeping. More storage instead of a 3-meter (10-foot) wardrobe. No chairs covered with clothes in the bedroom. And less dust in the bedroom. More space and order in the bedroom. That all makes sense, I agree. Especially the obligatory “chair” found in many bedrooms. I’ll think about that, thanks.
Mycraft schrieb:
Silas, just like sockets everywhere inside and outside. Of course, electric roller shutters everywhere and temperature displays in every room. In my opinion, that should be standard. Wow, perceptions really differ. None of that was standard with our general contractor. We were first-time builders and only saw which thermostats we got once they were installed on the walls. It wasn’t really discussed during the selections, and we hadn’t thought about it until then.
All these things would have required us to actively “opt in,” and at the time we didn’t realize we would miss them.
Tom1978 schrieb:
Electric roller shutters with a central switch, so you don’t have to walk around to each one. I still wouldn’t miss electric roller shutters in terms of function; we use them rarely. But I simply don’t like the look of the straps.
