ᐅ Withholding Payments for Defects in the Shell Construction Phase
Created on: 9 Feb 2021 16:57
Kishihmen
The ceiling above the ground floor has just been concreted on our site. According to the payment schedule, a partial payment of approximately €30,000 is due.
However, our expert has identified several defects. These were formally reported to the general contractor (GC) with deadlines. The first deadline (2 weeks) passed without the defects being resolved; the second deadline is still running until Thursday (also 2 weeks).
So far, we have withheld about €17,000 of the €30,000. Our GC considers this amount far too high and insists on payment.
Since we are currently concerned about the potential insolvency of the GC (the structural builder, brick supplier, steel supplier, and light well supplier have not been paid), we want to keep the deduction as high as possible. However, since we are not construction professionals and want to avoid the risk that withholding too much for defects could backfire, I hope that some experts here can provide us with a rough cost estimate.
P.S. Our lawyer has been contacted, but the appointment is only scheduled for 17.02, and I fear we cannot hold off the GC until then.
Defect 1:
At the transition between the basement and the ground floor, no damp-proof course was installed at the base of the first course of blocks.
The basement is already fully lined with Styrodur insulation, and the excavation pit has been backfilled.
Cross-section through a building wall with heated ground floor, foundation, insulation, and base plaster.
Defect 2:
In some areas of the structural shell, the minimum offset of the bricks was not observed; in places, up to 7 courses of bricks were laid directly on top of each other.
Construction site brick wall made of red bricks, visible mortar joints, upper foil covering the wall.
Defect 3:
This is a row house. Mineral wool boards were installed between the buildings for sound insulation. At one externally visible spot, there is a gap of about 80cm (31.5 inches) depth and approximately 20cm (8 inches) height between the boards. After reporting the defect, the structural builder just “stuffed” mineral wool boards into the hole. According to our lawyer, this does not reliably ensure soundproofing.
Defect 4:
The area where the patio doors will later be installed was cast in concrete. Here, the reinforcing steel protrudes from the wall. According to the expert: This means that a proper bond between the reinforcing steel and concrete is not sufficiently ensured. It is assumed that adequate long-term corrosion protection of the reinforcement steel is not established. Furthermore, with insufficient concrete cover over the reinforcing steel, adequate fire protection is not guaranteed.
Defect 5:
In the floor slab area, the mineral wool board was not properly secured. As a result, it is quite wavy. This is particularly problematic in the stairwell area, where in some places only 10cm (4 inches) of concrete remain above the mineral wool board. The partition wall bricks have a thickness of 17.5cm (7 inches), though.
Construction site: concrete beam with joint, sealing compound, wooden framework, and measurement marks.
Defect 6:
The mineral wool boards were not installed tightly enough in some areas, allowing concrete to seep between the boards and create a sound bridge.
Construction site foundation made of concrete with wooden forms, steel reinforcement, and wet cement mortar.
These are the (known) defects so far. I would greatly appreciate it if anyone could roughly estimate the costs associated with these defects.
Construction site foundation: concrete block, reinforcement, and wooden forms
Fresh concrete foundation with steel reinforcement and wooden forms in an excavation pit.
11ant10 Feb 2021 15:58
Kishihmen schrieb:
How can I make these defects "undisputed"? Do I even have a chance?
The field of declaratory (or negative declaratory) actions illustrates very well why legal advice laws do not consider informal advice sufficient. And you still have to somehow get through the years until your chance comes.
Snowy36 schrieb:
Because who wants to take responsibility for what someone else has messed up...
We recently discussed that as well, keyword: "preceding trade."
icandoit schrieb:
The poor workmanship pockets seem to be common. Here, @11ant criticizes them in nearly every second post.
Poor workmanship pockets occur wherever architects are replaced by draftsmen and masons by stone stackers. It becomes most obvious on the finished building when, for example, a general contractor is in charge of the brick facing but employs unskilled laborers for the screed work. There is a causal connection between planning negligence and poor workmanship pockets: if you only deal with wall thicknesses and not the full dimensions of the bricks or blocks, you end up planning wall sizes that can only be built by constantly balancing between "cutting or cheating." The result is the wrong bonding length or the application of mortar where it doesn’t belong. Carelessness is no mystery — even fools can do it better than people who paid close attention in school.
Smialbuddler
10 Feb 2021 19:47
OT:
Estrich-Achmeds
I don't want to offend you and I always find your posts very interesting. However, even when you put quotation marks around it here, the expression is discriminatory and unnecessary.
Snowy36
10 Feb 2021 20:10
Kishihmen schrieb:
He says these are definitely defects. He also says he will no longer pay the general contractor and advised us to consult a lawyer. However, he admits that he doesn’t know the market prices on the “end consumer market” well enough to provide us with accurate figures.
That’s actually my problem right now. I’m not knowledgeable enough in this field to properly break down the invoice.
Why not? This is more time than they effectively spent working on building the masonry for the floor. What would be a reasonable deadline for correction?
Two weeks is reasonable... I can say that from experience. Nobody really believes he will actually come and tear it down.
11ant10 Feb 2021 23:47
Smialbuddler schrieb:
I don’t want to step on your toes and always find your posts very interesting. However, even when you put quotation marks around it here, the term remains discriminatory and unnecessary.
Then you appear to have missed the two posts https://www.hausbau-forum.de/threads/rohbau-mit-abgelaufener-baugenehmigung.33769/page-5#post-432423 and post #32 in the same thread, where I explain the use of the term.
Hausbau081511 Feb 2021 08:46
I have skimmed through the posts here and noticed some clear parallels.
Have you issued a formal defect notice to the general contractor (GC)? As long as you haven’t accepted the work yet (which I assume you haven’t), they have to prove that their work meets the quality standards. This means they need to certify it for you. Until then, I wouldn’t pay anything at all. You have the right to withhold double the estimated cost of defect remediation, and these costs appear to be substantial in your case.
My “butcher’s house” had defect remediation costs of around 100,000 euros, according to an official inspection report, and no follow-up company wanted to take it on. Even there, they talk about demolition because no one wants to assume warranty liability for the previous contractor’s poor work, and we are already much further along than you are.
At this point, only a competent architect—who also has contacts to reliable firms—and a good lawyer can help to get out of the old contract and possibly claim damages. The latter, however, will be difficult. I have a court ruling that my shell construction company owes me 130,000 euros in damages. But I might as well throw it in the bin because the GC sold the company to a Polish contractor who is now untraceable.
Mehrfamilienhaus im Rohbau mit Gerüsten, roten Backsteinen und Ziegeldach
Tolentino11 Feb 2021 08:55
Looks like someone waiting for their date who got stood up.
🙁 my sincere sympathy. I always keep your story in mind whenever I see the botched patches on my ground floor walls...
Yes, I know, it's nothing compared to what you have, but I have a bad feeling about this...
Wall made of red bricks with green mortar in many joints, construction site environment.
