ᐅ Utility room next to the bedroom
Created on: 31 Dec 2019 08:33
Specki
we are currently in the early stages of planning the layout of the individual rooms. As it stands, it seems practical to place the utility room next to two bedrooms.
I am wondering if this is a good idea or if the noise generated in the utility room will be too loud.
The planned equipment includes:
Water distribution
Inverter for the photovoltaic system
Heat pump (either air-to-water heat pump with a split unit or ground-source heat pump)
Controlled mechanical ventilation with heat recovery
Storage space for miscellaneous items
This area is definitely planned to be constructed using a timber frame system. I am thinking it should definitely have double studs with mineral wool insulation in between. I would handle the interior construction (timber frame walls) myself. The door will certainly need a gap or similar for air exchange, and right next to it at a 90° angle will be the door to the bedroom.
What do you think? How loud is the noise level likely to be? Can it be insulated well enough to ensure good sleep?
Regards
Specki
tomtom7931 Dec 2019 09:22
Forget it; when a heat pump is running, there is a constant humming noise. You will definitely hear this, especially at night. And you can't simply turn off a heat pump because you need the heat.
guckuck2
31 Dec 2019 09:42
I wouldn’t do it either.
Pinkiponk
31 Dec 2019 09:50
Specki schrieb:
it might be recommended
If it’s only “recommended,” I would follow the advice of the previous commenters.
If, for whatever reasons unknown to us, there is no other option, you will have to try to live with the noises that might be heard in your bedrooms. There are also people who live near airport runways or next to freight trains passing by night after night.
We currently still have an oil heating system from 2001, which we could hear in the bedroom (we could relocate the bedroom, but for other reasons we don’t want to), but we have gotten so used to it that we no longer notice it.
allstar83
31 Dec 2019 09:55
Are the noise levels of a mechanical ventilation system with heat recovery (Zehnder Q350 planned) comparable to those of a heat pump? We have a similar setup, but only with mechanical ventilation (and district heating).
Personally, I had noted to consider a limestone wall or something similar here.
kaho67431 Dec 2019 10:25
Show us your plans.
With the low roof pitch and knee wall, it’s easy for non-experts to get confused about the staircase and angled ceilings. I recommend placing the children’s room upstairs. For example, like this:
Floor plan of a house with bedroom, bathroom, kitchen, living room, dining area, and utility room.
Floor plan of a building with office, gallery, heating/storage, K 18, and staircase.
Two-story house with gray facade, dark roof, many windows on the grass.
Specki
31 Dec 2019 10:52
Hello Katja,
Thank you very much!
The house layout you designed isn’t exactly what we’re looking for, BUT it definitely brought some great ideas to the table! Of course!
Technical room on the lower floor, two children’s bedrooms upstairs plus a storage room. A study on the ground floor.
The kids would first use the study on the ground floor as a bedroom, and when they’re older, each would get their own room upstairs.
That would be a good option.
I like the drawings—what software is that? I’m guessing it’s not freeware...
We’re currently experimenting with Sweet Home 3D, but it’s not ideal, especially when it comes to sloped roofs.
Thanks again!
Specki
