ᐅ Zoning plan and the resulting house design
Created on: 18 Dec 2019 15:00
Specki
Specki
18 Dec 2019 15:00
We are planning to build a new house and now have some questions regarding the zoning plan.
Maybe you can provide some concrete answers or estimates about the situation.
I will probably visit the local authority again on Friday to clarify some details more specifically.
A brief background and framework:
We own parcel number 2414 and the adjacent plot at the back, which is outlined in purple and marked with a circle for better identification.
The total plot area is approximately 750 sqm (8079 sq ft).
We currently live in the front house on parcel number 2414 and use the rear plot as a large garden.
The street to the north is not yet constructed but was planned for 2020.
Since the current house is an older building from the 1970s with two apartments, we would prefer to build new at the rear. Currently, with two children, we live in only 95 sqm (1023 sq ft). As my wife is self-employed and has a home office, the kids only have one shared bedroom, so it is quite cramped.
The street has been planned for many years; now the city has finally acquired the last parcel to enable its construction. According to the municipality, it is expected to be built next year.
So, we took a closer look at the zoning plan. Unfortunately, I am not very pleased with it.
I will try to organize the individual points and questions a bit.
Let’s see how far we get with this thread.
Attached is the relevant excerpt from the plan.
1. It is a mixed-use zone.
2. The maximum number of full stories is set to 1 (mandatory). This means I can only build one full story, and the attic floor may have a ceiling height of 2.2 m (7.2 ft) or more only on up to two-thirds of the area.
3. Roof pitch is specified as 22° - 28° according to the zoning regulations.
4. The important regulation states: “The height of knee walls, measured from the top of the ceiling to the intersection of the outer edge of the masonry with the top of the rafter, must not exceed 0.5 m (20 inches).”
So there is no much leeway here either. This means that the usable attic space will be significantly smaller than the ground floor.
5. Floor area ratio (FAR) = 0.25; I see this as uncritical for our project.
6. Plot ratio = 0.3; also uncritical for us.
7. According to the regulation: “Dormer extensions on main buildings are only permitted with flush-mounted windows.” For me, this means dormers are not allowed, only roof windows.
We had considered building a house with a ground floor plus upper floor. Also with some knee wall upstairs, but 0.5 m (20 inches) is quite tight. This causes a significant loss of usable area in the upper floor, so I would need to make the ground floor larger.
We are planning a house of about 130 sqm (1399 sq ft) for a family of four, including a home office.
Currently, we have three rough ideas:
1. Ground floor + upper floor with reduced area. So ground floor slightly larger and upper floor with knee wall. Ground floor maybe about 75 sqm (807 sq ft), upper floor about 60 sqm (646 sq ft). Roof pitch as steep as possible at 28°.
2. Alternatively, basement + ground floor with about 75 sqm (807 sq ft) each and possibly a “cold” attic and gable roof with 22°. In this case, the basement would need living rooms (children’s rooms/home office). Therefore, a basement with good insulation and large basement windows would be required.
3. Or a bungalow with about 125 sqm (1345 sq ft). Advantage: the total living space is slightly smaller as no stairs are needed and one bathroom is sufficient. No intermediate floor. Space under the roof can be used as storage. Disadvantage: large foundation slab and roof, so more plot area is lost.
How would you assess the three options in terms of cost?
We want to build as cost-effectively as possible, without unnecessary extras.
Additional relevant info: the house is planned to meet KFW40 energy standards. Either a controlled mechanical ventilation system or decentralized ventilation system will be installed.
We will definitely do some DIY work: plastering, flooring, electrical installations.
Do you have any other suggestions? Pros and cons?
We also once considered a multi-family house with 3 or 5 units, but after reviewing the zoning plan, this seems definitely off the table.
I expect there will be more threads later as our planning progresses in detail. This is just the initial starting point.
Thanks in advance for your help.
Regards,
Specki
Lageplan mit Grundstücksgrenzen, Straßen und Gebäuden, markierter Bereich
E
Escroda
19 Dec 2019 19:56
Specki schrieb:
a ceiling height of 2.2m (7.2 feet)
Where does the 2.2m (7.2 feet) come from?
My favorite, if it weren’t for the rather shallow 28° roof pitch.
Specki schrieb:
2. Alternatively basement + ground floor
Only if there is at least a 1m (3.3 feet) difference in ground height within the building plot.
Specki schrieb:
3. Or a bungalow
The plot size and floor area ratio are large enough (when was the development plan issued?). Considering the limited roof pitch, my preferred solution.
Specki schrieb:
Disadvantage: ..., large roof.
With a south-facing orientation and photovoltaic system, this is rather an advantage.
Specki
19 Dec 2019 20:45
Escroda schrieb:
Where does the 2.2m come from?
I found the definition online:
"What is meant by a full storey?
A full storey is a above-ground floor that has a clear height of 2.20 m (7.2 ft) or more over at least half of its floor area. A top floor is only considered a full storey if it has the clear height mentioned in sentence 1 over more than two-thirds of the floor area of the storey below."
Escroda schrieb:
My favorite, if it weren’t for the modest 28° roof pitch.
Yeah, I kind of think the same.
Escroda schrieb:
Only if there is at least a 1m (3.3 ft) difference in ground level on the building site.
Not the case. Completely flat.
Escroda schrieb:
Plot size and floor area ratio are large enough (how old is the zoning plan anyway?). Given the limited roof pitch, my preferred solution.
Yep, the bungalow would be no problem. The zoning plan is from 2001 and is still valid according to the city.
Escroda schrieb:
With south orientation and photovoltaics, rather an advantage.
Sure, you can fit a decent-sized photovoltaic system on that. I’m currently installing a 24.5 kWp system on my current house. But roof area costs more than what the photovoltaic modules can generate, I’d say. So it’s not necessarily an advantage, but with photovoltaics it’s not quite such a big disadvantage either.
Thanks for your replies!
I just don’t understand the strict limitations in the zoning plan.
I totally get that you can’t just put a huge block there now. But I think the plan really restricts you a lot.
Regards
Specki
19 Dec 2019 21:51
I would build a shed roof house on that plot, if permitted.
The upper floor could be designed so that the children's bedrooms are there, and it would essentially count as "half a storey" in terms of calculation. If the other rooms are on the ground floor, then the knee wall height is sufficient.
By the way, I find 130sqm (1400 sq ft) including an office a bit too small if the house is built without a basement.
Specki
19 Dec 2019 22:48
Only gable roofs with a pitch between 22° and 28° are allowed according to the regulations.
Yes, most people probably consider that too little. It is sufficient for us.
19 Dec 2019 22:56
Okay. Then the bungalow, with the storage room including technical equipment in the roof space.
