ᐅ Floor Plan Design for a Single-Family Home of Approximately 150 m²
Created on: 12 Feb 2018 18:09
chrisw81
After a long search, we signed the notarized contract for the land purchase at the end of December. We are now actively planning the floor plan. Unfortunately, the plot is somewhat awkwardly shaped (not rectangular), which creates some limitations for the layout from our perspective. We already have a first draft, but there are several areas we don’t like and are unsure how to improve. Maybe you have some ideas; we would appreciate your input.
Plot size: 601 m² (6465 sq ft)
Building envelope, building line, boundary: Building line with the house on the west side
Peripheral setbacks: 7 m (23 ft) from the street (north), otherwise the usual 3 m (10 ft)
Number of parking spaces: 2 desired
Number of floors: 1 full story allowed
Roof style: Gable roof
Design style: open construction method
Orientation: South
Maximum heights / limits: Ridge height max. 8.5 m (28 ft)
Additional requirements: Max. 100 m² (1076 sq ft) of built-up area
Style, roof form, building type: Solid construction house, rectangular, no bay windows, no projections, etc., gable roof
Basement, floors: no basement; 1.5 stories
Number and age of residents: 2 people, age between 30 and 40, possibly children later
Space needs on ground floor and upper floor: Ground floor – living/dining room, kitchen, guest toilet, utility room, office
Office: family use or home office?: family use
Guest stays per year: 20 days
Open or closed architecture: open living area, closed hallway
Conservative or modern style: conservative
Open kitchen, kitchen island: open kitchen, island without cooktop
Number of dining seats: 2-4
Fireplace: yes, chimney planned
Music/stereo wall: no
Garage, carport: carport
Further wishes, special features, daily routine, and reasons for preferences:
- A wardrobe area on the ground floor is important where coats can be stored relatively out of sight.
- On the upper floor, it would be nice to have an open gallery with a desk or similar (not a must and not necessarily next to the stairs).
- A walk-in closet would be nice but not essential.
- A storage room on the upper floor is very important since we do not have a basement.
Who created the design:
- Basic design by the construction company (FIBAV Stadthaus Vision Studio)
- DIY modifications based on online floor plans (especially Viebrockhaus Maxime 330)
What do you particularly like? Why?:
- Layout of the living/dining area and the narrowing kitchen reduces the hallway effect a bit
- Many windows in the living/dining area
- Wide hallway on the ground floor
What do you dislike? Why?:
- Few options to place furniture (dresser, wardrobe) in the ground floor hallway due to many doors
- Very large hallway upstairs, considered wasted space
- Bedroom is quite small; should be the largest room upstairs (preferably 16 m² (172 sq ft), children’s rooms rather 14 m² (151 sq ft))
- Stair placement limited by chimney location
- Door placement upstairs limited by chimney
- A staircase rotated 90 degrees (entrance next to front door) would appeal more
- Difficult to align windows upstairs and downstairs on the gable end vertically
- Floor-to-ceiling windows upstairs; wider windows with a sill height around 100 cm (40 inches) would be preferred
Price estimate by architect/planner: 200,000 €
Personal price limit for the house including equipment: 210,000 €
Preferred heating technology: gas heating
What details or expansions could you give up?
- Can do without: gallery next to stairs upstairs. Living area could also be narrower (e.g., 4.20 m (14 ft) instead of 4.47 m (15 ft))
- Cannot do without: storage room upstairs, shower in guest toilet, extra natural light in the ground floor hallway (e.g., side panel on front door or window)
Why was the design made this way? For example, standard plan from planner?
- Since the house has very little space on the south side, the house should be very narrow in order not to waste more space to the south. It should be wider so that living, dining, and kitchen areas face south as much as possible.
Were corresponding wishes from the architect implemented? No architect meeting has taken place yet.
How can the ground floor hallway be better designed to fit a wardrobe? Can the stairs be positioned better or replaced? Should the hallway be enlarged and living space reduced? How can the upstairs hallway be better utilized? Can the bedroom be enlarged? Is it possible to swap the bedroom with another room, e.g., move it to the southeast to allow a walk-in closet?
Thank you very much in advance for your criticism and suggestions!
Lageplan eines Baugrundstücks mit Parzellen, Straßenverlauf und Gebäudestrukturen.
Grundriss: Kochen/Essen/Wohnen, HWR, WC, Diele, Gast, Treppenhaus, Schornstein.
Grundriss Obergeschoss: Zimmer 1, Zimmer 2, Schlafen, Bad, Flur/Galerie, Abstell, Schornstein.
kaho6742 Mar 2018 13:50
chrisw81 schrieb:
Would you still do something like that if you have children?
Well, if you’re planning on having two... two at once is rather difficult to plan for.
An 80 cm (31.5 inch) shower is definitely not ideal. That kind of setup is usually built in small studio apartments where space is limited and the tenant is exploited without mercy.
Still, you can go to the architect with your wish list and ask them to make it nicer, I think. However, I wouldn’t present a full design immediately. First, wait for their ideas so they can plan freely and without influence. Maybe they have a brilliant solution in store.
kaho6742 Mar 2018 20:47
Now, while tinkering, the chimney ended up right at the roof ridge. Is it centered enough?
3D house model: gray, two-story residential building with dark tiled roof on green lawn.
Floor plan of a house with two children’s rooms, bathroom, hallway, and staircase in the plan
Floor plan of a house: central hallway, dining table, kitchen, guest room, utility room, storage room, and shower.
11ant2 Mar 2018 23:33
I find the floor plan layout quite well done as it is, and the windows as well.
kaho6743 Mar 2018 09:06
I find the floor plan layout quite successful as it is, and the windows as well.
However, chimney 2 becomes a problem again here.
3 Mar 2018 09:24
But do you know what a modern “chimney” for a gas heating system actually looks like?
kaho6743 Mar 2018 13:44
But do you actually know what a modern "chimney" for a gas heating system looks like?
No. Does that change anything about the location question?
