ᐅ Ventilation in New Construction (Central vs. Decentralized), Noise Disturbance
Created on: 20 Jun 2016 20:41
Kiri123
I am currently considering the ventilation system for our planned new build (details: Kfw 70, 2 full floors + basement + unheated attic, hipped roof, 200m² (2,150 sq ft) living space). We live in a rural area and like to keep the windows open sometimes, so we don’t necessarily have to rely entirely on mechanical ventilation.
I am torn between a central controlled mechanical ventilation system with heat recovery, a central exhaust with decentralized supply air, and decentralized supply/exhaust with heat recovery. My requirements are:
• Ventilation of bathrooms (master bathroom, children’s bathroom without windows, and guest toilet without windows) with demand-controlled ventilation based on usage
• I want to avoid having to open windows every few hours while still maintaining high indoor air quality
• Not too noisy, as I am very sensitive to noise when trying to sleep
• I am also sensitive to dry air; for example, I cannot tolerate air from air conditioning or sports halls very well
Below are the pros and cons of each system as I see them:
Central Controlled Mechanical Ventilation with Heat Recovery
+the most mature system
-expensive (I estimate about 10,000 to 13,000 Euros)
-more complex planning, including suspending and boxing in ducts
-(I heard from a provider of decentralized ventilation systems: as soon as I turn up the ventilation in the living room, more warm air is blown into the bedroom – not desirable)
-the indoor air quality in the prefabricated houses with controlled ventilation that we visited was always poor. That makes me skeptical
Central Exhaust with Decentralized Supply Air
+cheaper (maybe 2,000 to 3,000 Euros?)
+should meet minimum requirements
-energy wasted (or can I reuse the heat energy somehow? I am planning to install an air-water heat pump for heating and hot water production. Maybe the heat can be used here in a useful way). I was advised against a complete exhaust heat pump. Perhaps combined exhaust/fresh air heat pumps exist?
-cold air from decentralized supply? (I have read that with proper planning this is no problem because the supply air mixes “appropriately” with the existing indoor air)
-somewhat contradicts the idea of energy-efficient houses. Still, it’s probably more efficient than constantly having windows tilted open.
Decentralized Ventilation with Heat Recovery
+If I simply install one of these ventilators in the living-dining area, the master bathroom, and the children’s bathroom (+ exhaust in the toilet), the minimum requirements should be met. I estimate about 3,000 Euros (1,000 Euros per unit)
-if I want to cover all other rooms to avoid window ventilation entirely, it gets more expensive (maybe ~8,000 Euros) and:
-I would have many holes in the building envelope
-I hesitate to install these devices in bedrooms or children’s rooms because I think they may be too noisy.
Could you please help me with the decision? Maybe by sharing your experience or confirming or disproving some of my points? I would also like to see different ventilators in practice. Do you have any tips? I heard it might be possible somewhere in Berlin, but I live in the postal code area 5xxxx.
I look forward to your opinions.
Kiri
Sebastian79
14 Aug 2016 20:42
Not just in quotes – it actually cools much better than a mechanical ventilation system for indoor air quality can.
T21150
14 Aug 2016 20:47
Sebastian79 schrieb:
Not only in "", it actually cools much more effectively than a mechanical ventilation system can.
Absolutely, definitely.
Mechanical ventilation on "exhaust only, level 3," windows open. The slight negative pressure created (only very slight since the building envelope is no longer airtight) by the mechanical ventilation effectively pulls in fresh air through the windows, creating a pleasant airflow. Tried it myself, works perfectly.
We rarely have tropical nights (over 20°C (68°F)) anyway, but indoor temperatures above 23°C (73°F) in summer are quite common, so we gladly use this method repeatedly.
Sebastian79
14 Aug 2016 21:22
I have consistently set a slight negative pressure—not only beneficial for the building fabric but also useful in situations when the window is open.
At least the mutant spiders under a construction tarp have shown my wife that the window should only be open occasionally.
T21150
14 Aug 2016 21:24
I have arachnophobia.
Good thing we don’t have any spiders here. Anything with more than four legs really unsettles me.
When it comes to spiders: I run.
Sebastian79
14 Aug 2016 21:33
Then you should never go here – I have never seen such huge beasts in Germany outside of a zoo.
Terrifying, really...
Peanuts74
16 Aug 2016 08:50
Oh, we can also bring out some proud examples. We even had one once that you could hear running if it was completely silent...
