ᐅ Flush or Full-Height Interior Doors
Created on: 9 May 2016 12:35
daniels87
daniels87
9 May 2016 12:35
Hello!
Has anyone here built with flush-mounted (wall flush) or floor-to-ceiling interior doors?
We would like to have these on the ground floor as a highlight.
How do they hold up in everyday use? What did you pay for them?
daniels87
Sebastian79
9 May 2016 15:14
So, the frame flush as well? That’s not easy to achieve in practice, since everything has to be very straight.
On the ground floor, we have flush doors, meaning the frame and the door leaf are flush, and the doors are 2.32 m (7 ft 7 in) high.
The ceiling height on the ground floor is 2.70 m (8 ft 10 in) – it was already difficult enough to find a reasonably priced supplier for this special dimension.
Without installation, a white lacquered door with a magnetic lock and without handle fittings costs 530 euros.
daniels87
9 May 2016 16:12
So far, I only have one quote for standard-height interior doors. They are priced at 750€ including installation.
I expect flush doors to be significantly more expensive due to the higher effort involved, as the frame needs to be plastered flush during the rough construction phase. However, I have not received a quote for those yet.
Two companies have already declined immediately, apparently due to lack of experience and interest.
tomtom799 May 2016 22:48
Sebastian79 schrieb:
We have flush doors on the ground floor, meaning the frame and door leaf are flush, with the doors being 2.32m (7 feet 7 inches) high.
Already installed? I would like to see them if possible.
Neige9 May 2016 22:57
I would plan with a double-frame door casing including a bottom frame. If the ceiling height allows, possibly with a transom window or an upper panel.
Sebastian79
10 May 2016 08:58
tomtom79 schrieb:
Already installed? I’d like to see that if possible
Unfortunately not yet – they are at the supplier, but I still need to finish plastering/painting and install the flooring.
