ᐅ Is the house price reasonable?
Created on: 1 Sep 2015 11:19
schuckie
We are currently considering a prefabricated house from Bien-Zenker. It was built at the end of 2013, so it’s almost new. A family with five children lived in it for one year. The marriage broke up and the house is now being sold. Some interior work was done by the owners themselves, which is visible in places (bathroom grout is poorly done).
The details are as follows:
  • Living area 180 m² (1,938 sq ft) over two floors
  • Ground floor includes a utility room, open kitchen/living/dining area, bathroom, guest room
  • Upstairs there are 4 bedrooms and a bathroom
  • KfW 70 energy standard with district heating, controlled ventilation system Lunos with heat recovery
  • Plot size 475 m² (5,110 sq ft), price was 250 € per m²
  • No basement
  • The house is very simple, gable roof, no balcony, knee wall 1.60 m (5.25 ft)
  • Detached garage 7.50 m (24.6 ft) long
  • Driveway and parking spaces paved
  • Terrace slabs are laid
  • The garden is undeveloped, no fence, lawn, plants, etc.
  • 2 bathrooms: downstairs with shower, upstairs with shower and bathtub, standard quality
  • Large kitchen with Bosch appliances
  • Flooring is laminate
  • 3 solar panels on the roof
The purchase price is €390,000 plus realtor fees. The walls all need repainting as they’re quite marked by the children. Some baseboards need repair. The garden still needs to be landscaped.
What do you think? Is the price reasonable?
Thank you very much.
Timo
merlin83
1 Sep 2015 21:06
Müllerin schrieb:
What do you think about the wall construction from Bien-Zenker? For us, this was a reason to exclude them from our shortlist... (because the walls are too thin, with no wooden board behind the plaster on the interior, meaning special anchors are always needed)
How often have you drilled into the wall over the past 12 months?
Müllerin
2 Sep 2015 10:08
Everyone has to decide for themselves, I’m just pointing out that it doesn’t work for US.
If there is no wood board behind the plaster anymore, you have to plan differently, also in terms of load-bearing capacity, compared to having a board.
For us, "often" was not even the question; I prefer to use a screw like a Spax and hang everything I need on it.
Moppetüte *12.12.12
schuckie
2 Sep 2015 10:19
What does this mean? Do I have to use hollow wall anchors for everything if it is too heavy? Is it possible to mount a TV?
How does it actually work with installing electrical boxes?
Müllerin
2 Sep 2015 10:48
Cavity anchors, yes.
A TV mount should be possible; I think the consultant mentioned something about 50 kg (110 lbs), but I’m not entirely sure.
No idea about the electrical boxes; are the building plans still available? They usually show where reinforcements, pipes, etc., run inside the walls.
Moppetüte *12.12.12
Wastl
2 Sep 2015 11:01
Installing electrical boxes later in a prefabricated house is complicated because the beams usually run vertically. This means you have to run the wiring cables all the way to the ceiling (or the floor). You need to hit the cavity (the space between the wooden beams). In principle, this is not too difficult—just use a hole saw and get started—but be careful not to go too deep to avoid damaging the vapor barrier.
bernie
2 Sep 2015 12:28
So if the plot of land is already worth around 130,000 euros, then I find the offer absolutely not too expensive, but rather reasonable for 180 sqm (1,938 sq ft) of living space.
