ᐅ Why does the BILLY back panel sometimes squeak under load?
Created on: 18 Jun 2016 08:13
TABEPI
I have a question that has been bothering me for a while regarding my IKEA Billy bookshelf, and I hope someone here can help:
Why does the back panel of the BILLY bookcases sometimes squeak under load?
More specifically, when I place weight on the shelves or slightly move the unit, I hear a clear squeaking noise that seems to come from the back panel. The back panel is just a thin wooden board inserted into grooves. I suspect that either the material itself or the way the back panel is fixed might be causing this, but I’m not sure. Could it also be related to moisture or temperature changes?
Maybe someone is familiar with this issue and can explain what causes it and whether it can be fixed? Thanks in advance!
deoke
19 Jun 2016 07:50
Renla47 schrieb:
Sometimes it’s not just mechanical friction, but also dust or small wood particles that accumulate in the groove and can cause creaking or squeaking when moving the back panel.
Exactly, that point is important.
To add: The back panel is usually simply inserted into one or two grooves. Over time, the grooves may widen slightly, for example due to fluctuations in humidity or minor material deformation, which results in a looser fit. The back panel can then slip back and forth under load and cause noise.
To fix this, I recommend the following steps in order:
1. Clean the groove (as Renla47 mentioned)
2. Lightly sand the groove if the edges are too rough
3. Use felt strips, thin foam strips, or even adhesive pads as a buffer
4. If the back panel is damaged, consider replacing it with MDF, which is more dimensionally stable
The squeaking is therefore a combination of material, assembly, and environmental conditions.
flota
19 Jun 2016 13:41
To look at the topic from an additional perspective:
The BILLY shelves are designed so that the back panel acts as stabilization against lateral warping. Depending on how much weight is placed on the shelves and how firmly the unit stands or how solid the wall behind it is, slight movements can occur. These movements are enough to cause the thin back panel to rub against the groove, which explains the squeaking.
It is also important to check whether the shelf is truly standing completely level. Even minimal tilts or uneven floors can cause movements that stress the back panel and generate noise.
Therefore, adjusting the leveling feet or placing small wedges underneath is an option to minimize the noise.
deoke
20 Jun 2016 08:22
flota schrieb:
One should also check if the shelf is really placed completely level. Even slight tilts or uneven floors can cause movements that put stress on the back panel and produce noises.
Good point, flota.
It would be interesting to know exactly how TABEPI set up their shelf, whether it is positioned against a wall or free-standing, and if the back panel squeaks only under heavy load or also during everyday use.
Additionally, squeaking usually happens when the individual parts move against each other. One solution could be to secure the shelf to the wall with brackets to further reduce movement of the back panel.
TABEPI
20 Jun 2016 12:04
Thank you for the many helpful responses!
I’ll try to be more specific: The shelf is placed directly against the wall and is fully assembled. I don’t have any issues with slanting; it stands quite stable. The squeaking only occurs when I put some weight on it, for example, placing a few books on a particular shelf. So it’s part of normal everyday use.
The idea of putting felt strips between the back panel and the groove sounds promising, as does fixing it with small nails.
I plan to clean the back panel and then try these options.
Thanks also for the tip about dust particles—I hadn’t thought of that.
If anyone has more ideas on how to prevent the squeaking permanently, please share! 🙂
