ᐅ Why does the back panel sometimes come loose during assembly of BILLY?
Created on: 6 Feb 2015 08:13
wulfplo
I have had a specific question about assembling the IKEA BILLY bookcase for some time: Why does the back panel sometimes come loose during assembly?
I have noticed in several cases that the back panel either does not fit properly or partially detaches while putting the unit together, which can affect its stability. I am using the standard tools and following the instructions.
It seems to me that the issue might be related to how the back panel is attached – often thin particleboard or fiberboard panels are slid into a groove. I wonder whether the problem is due to the material, the fitting, the assembly instructions, or possible installation errors.
Has anyone had similar experiences and can explain why this happens with BILLY models and how to best prevent it?
Thank you in advance!
LuMarcel438 Feb 2015 10:12wulfplo schrieb:
Does anyone here have specific experience or even a trick on how to secure the back panel in place without affecting the appearance of the BILLY shelving unit?I would avoid using additional screws, as they can compromise the structure.
It’s better to mount the shelving unit to the wall as recommended in the manual. This prevents it from tipping over if the back panel comes loose and maintains safety.
Alternatively, you can fix the back panel spotwise with a thin, transparent mounting adhesive. But use it sparingly to avoid any lasting marks.
