ᐅ Which material should I use for the driveway?
Created on: 2 May 2014 11:37
Marcel-1
2 May 2014 11:37
I am planning to pave my driveway soon. Now I am considering how deep to lay the gravel base. For frost protection, I will use gravel with a grain size of 0/32. I am thinking about 20 to 25 cm (8 to 10 inches) – would that be sufficient?
Thank you for your information.
Kurt1985-1
3 May 2014 00:54
Hi Marcel,
If the paved path is going to be driven on, a 20 cm (8 inches) thick layer of crushed stone is sufficient. The grain size you mentioned is adequate. However, below that, a frost-resistant substructure is necessary. This is important to prevent the paving from heaving during frost or thaw conditions. The topsoil must be removed and replaced layer by layer with crushed stone, compacting each layer thoroughly. The frost depth varies depending on the location and ranges between 80 and 120 cm (31 and 47 inches).
Roman-1
3 May 2014 06:40
I suggest you also obtain the technical information from the manufacturer of the paving stones. They can likely provide details on the bedding and joint materials as well. I believe there are also different installation methods depending on the type of paving.
Marcel-1
3 May 2014 09:11
Thank you for the responses. I am currently in the process of choosing the paving stones. I will ask about it there right away. Thank you for the tip.
Marcel-1
4 May 2014 07:57
I still have a question regarding the base layer. Yesterday, one building material supplier offered a mineral quartzite mixture 0/32, and another one offered a basalt with mineral mixture 0/32.
Are there any differences between these, and what would be recommended?
Thank you very much.
Annegret-1
5 May 2014 06:54
Hi Marcel,
It is very important that you follow the guidelines provided by the paving manufacturer. My husband did the same back then and it worked out well. We had a problem with ants. It was recommended to us to use gravel, which my husband also did. It still looks really good today.
Annegret
