ᐅ Which Ikea Pax doors come with soft-close features?
Created on: 10 Jul 2022 08:23
Meopa47
Hello everyone, I am currently planning to purchase an Ikea Pax wardrobe and I am particularly interested in the doors. My question is: Which Ikea Pax doors come with a built-in soft-close function? I have done some research, but the information is somewhat unclear, and not all door types seem to support this feature by default. It is especially important for me to know whether soft-close is integrated according to the original product design or if it can only be achieved through additional retrofitting. Perhaps some of you have experience with different models or know which versions come with soft-close as standard? Thanks for your help!
Gafiel
12 Jul 2022 07:44
One more point that is often overlooked: the soft-close feature of sliding doors is controlled by the track system, which consists of a combination of plastic and metal components that can be readjusted. If the door is heavily loaded or the tracks are slightly dirty, the damping effect may weaken. In contrast, with hinged doors, the damper is mechanically attached directly to the hinges, resulting in a different distribution of stress.
If it is important to you that the soft-close function works precisely over the long term, I recommend regularly checking to ensure everything is still properly adjusted. Especially with sliding doors, the adjustment of the rollers can be easily fine-tuned to optimize the soft-close effect.
Meopa47
12 Jul 2022 08:12
Thanks for the many helpful explanations! To sum up, I see it this way:
- Sliding doors usually come with a soft-close feature as standard, but the style is less suitable for me.
- Hinged doors do not come with a soft-close feature by default, but Ikea offers retrofit kits that are compatible and relatively easy to install.
- For special door fronts (glass, painted surfaces), you should check whether the kit fits before retrofitting.
- Durability and function are good with careful handling, but regular adjustment helps.
I will now take a closer look at the hinged door + soft-close combination. If anyone has practical tips for installation or experience to share, please feel free!
funon5
12 Jul 2022 08:43
A brief addition regarding installation:
Installing the soft-close kit is usually straightforward if you keep the following points in mind:
- Check the exact types of hinges before attaching the kit.
- Follow the included installation instructions or the online guides step by step.
- Make sure all screws are tight but avoid over-tightening to prevent damage.
If you already have experience with furniture assembly, retrofitting a cabinet usually takes only a few minutes per door. Otherwise, you might want to get some help, as the effort should not be underestimated—especially if the doors need to be removed first.
