ᐅ Which drill bit should I use for drilling into the ceiling to hang a light fixture?
Created on: 9 Sep 2024 14:01
Hafenguy
Hello forum community,
I hope this is the right place; if not, please feel free to move it.
Today, we tried drilling holes on the ground floor to hang some lamps, but we got stuck.
After drilling a short distance, we couldn’t go any further.
We tried several spots in the hallway, and only at one point were we able to drill through.
We suspect there is a steel beam, and the spot where we succeeded was where we didn’t hit the beam.
Attached is a photo of our drill bits. Our assumptions:
- The silver bit is for masonry and concrete
- The bits below are for wood
- Are the top bits suitable for metal, or do we need different ones for that?
Unfortunately, the instructions we found online aren’t very clear.
As a result, we already used the wood drill bit on the ceiling, which wasn’t good for it.
Is it even possible or recommended to drill through a steel beam, or should we try to find a spot where the masonry bit works well?
Drei Bohrer-Sets mit Spiralbohrern in grauen Halterungen auf Holzuntergrund.
RotorMotor
9 Sep 2024 21:24
Yes, this is just a drill "with vibration" and not a hammer drill. It is probably fine for wood and steel, but simply does not deliver enough impact for concrete.
The drill bit looks okay.
Buchsbaum066
9 Sep 2024 22:00
RotorMotor schrieb:
The drill bit looks fine.
Just order a HILTI SDS-plus TE-CX with a 6mm (1/4 inch) diameter, along with the appropriate anchors. That is more than sufficient for standard lamps. If you want to hang a chandelier, use a correspondingly larger size.
Hafenguy
9 Sep 2024 22:30
In the hardware stores, I only find the HILTI SDS Plus (without TE-CX).
If I understand correctly, this relates to the bit shank type.
Can I also use the one without TE-CX?
Buchsbaum066
10 Sep 2024 06:26
Specialized retailer or online.
The drill bit then has 4 cutting edges. Te-CX is important. SDS is, of course, the chuck type.
It costs 7.50 Euro. There are Hilti or Würth stores, or good tool suppliers. You can find these in every larger town.
RotorMotor
10 Sep 2024 07:25
Buchsbaum once again shows a lack of knowledge. Recommends SDS Plus drill bits for a drill with a chuck... It's a pity that people actually listen to that...
houser
10 Sep 2024 08:15
Buchsbaum066 schrieb:
Just order a HILTI SDS-plus TE-CX drill bit with a 6mm (1/4 inch) diameter and the corresponding anchors. That is more than enough for standard lamps. If you want to hang a chandelier, choose a larger size accordingly.
I’ve rarely read something this wrong. This would be fine for a rotary hammer, but here a hammer drill is being used, so the SDS drill bit does not fit. These drill bits are designed to break up the material primarily by chiseling, which requires the bit to move within the grooves—a motion that a hammer drill does not provide. Regular drill bits without SDS work with cutting edges and use light hammering during hammer drilling. SDS bits are not intended for hammer drills; only amateurs with no real knowledge do that.
