ᐅ What to do about wobbly Malm nightstands?
Created on: 4 Dec 2024 10:17
Pragla68
Pragla68
4 Dec 2024 10:17
I have an issue with my two Ikea Malm nightstands—they keep wobbling. They are placed on a fairly even laminate floor, but they are not very stable. It feels like the connection between the legs and the main body is giving way, or maybe the contact points with the floor aren’t secure enough.
I’m wondering what the best and most durable solutions are to fix the wobbling. Should the connections be tightened, additional pads used, or even small adjustable feet installed? What experiences do you have with Malm nightstands, and what has reliably worked for you to eliminate this constant wobble?
I would appreciate any tips and tricks, even if they require some DIY skills or materials. Thanks in advance!
Filippo
4 Dec 2024 11:28
Hello Pragla68,
Thank you for your detailed question; it makes giving precise recommendations much easier.
From experience, the issue with the wobbly Malm nightstands usually stems from two main causes:
1. The connection between the legs and the body is typically made with dowels and screws in Ikea furniture. Over time, these connections can loosen, creating slight play that results in wobbling.
2. The location itself: laminate floors can have minor unevenness that is not visible to the naked eye. Even a slight tilt can cause the furniture to rock.
My advice would be to proceed as follows:
- First, check all screws and connections using an appropriate Allen key or screwdriver. Tighten them, but not too much, to avoid damaging the material.
- If the screws were very loose, it can help to fix them with a small drop of wood glue or medium-strength threadlocker.
- If the floor seems to be the problem, test the nightstands without any floor protectors and check for wobbling.
- Get self-adhesive felt pads or foam rubber strips to increase the contact area at the feet and compensate for unevenness.
- For a more stable solution, adjustable threaded feet are available that you can install instead of the original glides. These allow precise height adjustment.
I would be interested to know if your nightstands have been in use for a long time and if there are any noises like creaking that might indicate wear?
This way, you can systematically narrow down the cause to achieve lasting stability.
koduga
4 Dec 2024 15:43
Pragla68,
I completely understand your concern—this kind of issue can be really frustrating, especially when all you want to do is relax. It’s great that you described the problem in such detail, as that makes it easier to provide targeted advice.
Sometimes it helps to take the piece of furniture out of use for a few days and then carefully check all the joints again. I once had a bedside table that still wobbled slightly after the initial repair. I ended up slipping small cork wedges under the feet as a temporary fix, and surprisingly, it worked quite well.
Another suggestion: if you’re not strictly attached to the original look, you can add small rubber anti-slip pads to the legs. These not only increase stability but also protect laminate flooring. If the Malm bedside table has been used for several years, the engineered wood at the joints might have slightly swollen or been damaged; sometimes you can repair this with small amounts of wood filler.
Keep at it—this problem can usually be solved with a bit of patience! 🙂
Elijah42
4 Dec 2024 18:19
You can usually fix wobbly Malm nightstands quickly by:
- Tightening the screws
- Attaching felt pads under the legs
- Using small wooden shims as an adjustment if necessary
This should restore stability.
Filippo
5 Dec 2024 08:06
Elijah42 schrieb:
Tightening screws
That is absolutely correct, but I would add that with IKEA furniture the material is often a bit softer. Therefore, I recommend paying attention to the correct torque when tightening the screws. Overtightening can damage the particle board, which may cause even more wobbling.
koduga schrieb:
Add anti-slip rubber pads
Good idea, the rubberized pads also prevent slipping on smooth floors.
Pragla68, maybe you can also check if there is a slight warping of the connector strips inside the cabinet. If so, attaching small metal brackets on the inside often helps to add more stability.
I am also curious whether one of your nightstands wobbles more than the other, or if the wobbling is the same on both? This can provide clues about the cause.
