ᐅ What is the ideal tile size for a bathroom?
Created on: 30 Aug 2020 20:50
Heidi1965
A dealer showed me floor tiles suitable for the bathroom, toilet, hallway, kitchen, and utility room, as well as wall tiles for the bathroom, which I liked. However, they are quite large:
Floor: 60 x 60 cm (25-- €/m² (10.8-- $/ft²)), R 10 AB; Thickness: 10.5 mm (0.41 inches)
Bathroom wall: 42.5 x 119.2 cm (48-- €/m² (20.0-- $/ft²)); Thickness: 10.5 mm (0.41 inches)
Advantages:
- Square tiles don’t create a lengthening effect in a narrow hallway
- Large wall tiles, especially in the shower, mean fewer grout joints, resulting in fewer issues with dirty or damaged grout
Are there any disadvantages?
Bookstar
30 Aug 2020 22:27
60x60 is a great size. I would choose it again anytime.
Tarnari30 Aug 2020 22:51
Do I understand this correctly?
Floor and walls have different dimensions?
I would opt for a uniform measurement because of the joint pattern.
hampshire
30 Aug 2020 22:57
Tarnari schrieb:
I would recommend using a consistent tile size based on the grout pattern.
Everything can be coordinated. Floor tiles 60x60 cm (24x24 inches), wall tiles 120x45 cm (47x18 inches), wall tiles only in the shower area and behind the toilet. Mosaic behind the washbasin. The grout pattern looks great. Don’t try to save on hourly labor costs, then it will work out.
Rule: It must be pleasing to the eye.
Good grout doesn’t deteriorate either.
Tarnari30 Aug 2020 23:07
hampshire schrieb:
Everything can be coordinated. Floor tiles 60cm x 60cm (24in x 24in), wall tiles 120cm x 45cm (47in x 18in), walls only in the shower area and behind the toilet. Mosaic behind the washbasin. The grout pattern looks great. Don’t save on hourly labor costs, then it will work.
Rule: It has to be pleasing.
Good grout won’t deteriorate.
That’s certainly true. We were shown various grout patterns. If the wall and floor grout lines don’t align, it looked strange to us. As you said, it has to be pleasing.
bauenmk202031 Aug 2020 09:51
Tarnari schrieb:
That is certainly true. We were shown different joint patterns. When the wall and floor joints don’t line up, it looked strange to us.
As you said, it has to be a matter of personal taste.
It looks strange when the wall and floor joints are just slightly misaligned. When using different tile sizes, it’s best to place the joints deliberately further apart.
Otherwise, I think you get used to anything. It also depends somewhat on the floor plan which tile sizes fit well.
Nordlys
31 Aug 2020 13:03
In reality, there are always things standing around. Towel racks, trash bins, shelves, cabinets, bathrobes hanging on hooks, and so on. Who would still notice any misaligned joints in such a setting?
