I have a specific question regarding the care of Billy (a rather moisture-sensitive plant) when humidity levels are particularly high. Specifically, I am interested in what measures should be taken to prevent mold growth, root rot, or other damage caused by excessive moisture.
I would also like to know if there are any special recommendations regarding watering, placement, or fertilizing that are important for Billy. Thanks in advance for your expert advice!
Hello Eike56,
With high humidity, the care routine for Billy does indeed change somewhat. First of all, you should make sure that the plant does not develop waterlogging despite the moist environment, as Billy is prone to root rot if the soil remains wet for extended periods.
A well-ventilated location is especially important—ideally with good air circulation to prevent moisture from standing on the leaves. This often means avoiding direct drafts as well as completely sealed rooms.
When watering, it is advisable to water only when the substrate has dried out—under high humidity, the plant often takes up less water than in dry air.
Fertilizer should also be applied sparingly to avoid promoting excessive growth since lush growth in high humidity is more susceptible to fungal diseases.
One more question: What is the exact level of humidity in your environment, and what type of substrate are you currently using? These details will help to further tailor the care!
Eike56 schrieb:
if there are any special instructions regarding watering, location, or fertilizing
Hi Eike56,
you’ve raised an important issue. High humidity can cause various challenges, especially for plants like Billy, which are somewhat sensitive.
To prevent problems such as mold growth and root rot, it is essential to ensure adequate ventilation, as Surela already pointed out. Additionally, I would recommend avoiding mulch or tightly sealed surfaces in the pot, as these reduce evaporation and retain moisture.
This is a very important point—you should always check before watering, for example with a moisture meter.
Also, waiting between watering sessions helps prevent rot.
If you want, I can share tips on proper air circulation and the ideal spot for the plant, if you tell me where Billy is located.
Surela schrieb:
the substrate is dry – with high humidity, the plant often absorbs less water
VINKU schrieb:
if you say where Billy is located in your homeI also find this very relevant, Eike56. The location is often underestimated. For example, if Billy is placed in a windowless room with warm, humid air, the risk of fungal growth increases significantly.
In general, I recommend in such cases a combination of a slightly open window (even if you have a radiator on low setting running) and a dehumidifier or fan.
lis64 schrieb:
Avoid waterlogging at all costsThis is essential, because despite humid air, the root zone must not remain wet. The substrate should also be as well-aerated and well-drained as possible.
As I mentioned: I will ask specifically about the surroundings again, because the best care depends on it.
