ᐅ Wallpaper or plaster? Which is better for a new build?
Created on: 8 Jan 2023 13:26
Gooosee159
Hello
We are currently considering how to finish the walls in our new build.
The interior and exterior walls are made of sand-lime bricks, and a few non-load-bearing walls are made of gypsum concrete.
We want to design the walls so that we can avoid settlement cracks for as long as possible. (These are unavoidable in new buildings.)
What options are available?
Applying a plaster finish on the walls
Paintable plaster, roller-applied plaster, or simply smoothing with a drywall finish to Q3/Q4 level and painting
Alternatively, wallpaper and painting
Non-woven wallpaper, non-woven "Raufaser" wallpaper, painter’s fleece
We want the walls to be either smooth or with a light to medium texture (we are still undecided)
It is important to us to avoid settlement cracks for as long as possible. Non-woven wallpapers are the better choice because they cover small cracks and will only tear if large cracks appear.
The application should be relatively easy to carry out by amateurs.
We plan to have the painter do the stairwell and ground floor.
We want to do the upper floor, attic, and basement ourselves because we don’t have enough budget to have the painter do everything.
What would you recommend?
What is the difference between painter’s fleece and non-woven Raufaser wallpaper?
Is the only difference that painter’s fleece is smooth and Raufaser has a texture?
Non-woven wallpapers are definitely preferable to normal paper wallpapers, right?
Thank you for your help
Pitiglianio
3 Mar 2023 11:15
I would like to revisit this topic and ask a general question.
Considering the rougher surface structure, would a Q2 plaster be more suitable for creating a concrete look?
