ᐅ Walk-in shower partition: only 118 cm of space available after tiling instead of 120 cm
Created on: 20 Feb 2017 13:40
Steffi33
Steffi33
20 Feb 2017 13:40
Hello, we installed a 90x120 cm (35x47 inch) shower tray intended to be used as a walk-in. This means a glass panel will be placed along the long side. Tiling was done only after installation. As a result, we now have only 118 cm (46.5 inches) of space available for the shower panel; otherwise, it would extend beyond the edge. My question is whether the vertical profile allows for a 2 cm (0.8 inch) reduction tolerance? Unfortunately, the offers never mention this. Does anyone have experience with this? Best regards, Steffi33
11ant20 Feb 2017 17:26
Hmm... Pictures can sometimes help with imagining things ;-)
wrobel20 Feb 2017 18:25
Hello
The dimensioning of the partition wall usually indicates the adjustment range.
However, 2cm (0.8 inches) below the nominal size is quite significant and rather uncommon.
Olli
Steffi33
20 Feb 2017 19:22
The adjustment range always refers to the stabilizing bar. It usually says something like "adjustable from 70 to 130 cm" (27.5 to 51 inches). 🙁
@11ant... does that help you?
Bathroom under construction with tiled floor, wall tiles, and open plumbing connections.
Knallkörper
20 Feb 2017 19:51
Have you already ordered the partition wall? If not, have a glazier make and install one for you. It often looks better and is more affordable.
Steffi33
20 Feb 2017 20:07
Hello Knallkörper, no, I haven’t ordered it yet... But then I’m missing the vertical mounting profile, right?
