manowar3024 Jun 2011 13:33Hello everyone,
we are currently in the early planning phase of our new build.
After researching the energy efficiency classes and the energy demand of our future house, I still have a few questions.
The house will have about 160 square meters (1,722 square feet) of living space plus a basement, spread over two floors.
I am planning underfloor heating in all the rooms on the occupied ground floor and first floor.
A water-heated stove or tiled stove will be installed on the ground floor, which will channel waste heat into a storage tank.
In addition, we want a ventilation system with heat recovery.
I think this setup should be sufficient during winter, since we will probably use the wood stove every day.
For the summer (when the stove is not in use), I was considering solar collectors with a storage tank. However, I am not yet sure about the maximum area available for solar collectors. I estimate around 8 square meters (86 square feet).
My question is:
Where can I calculate whether this setup will be sufficient for 2 people living in 160 square meters (1,722 square feet), both in summer with the solar collectors and in winter with the water-heated stove?
Or can you tell me if this will be enough?
I would prefer to avoid installing a gas connection if possible.
Best regards and many thanks in advance,
Joe
My question is:
Joe
Example: A building is offered/sold for €230,000. According to a manipulated consumption forecast, the final energy consumption (heating/domestic hot water) is estimated at 4300 kWh/year. The specific price of the building is therefore €53 per annual kWh of final energy.
A real (accurate) consumption forecast shows instead 6600 kWh/year of final energy due to inadequate system planning/device selection! Specific price €35 per annual kWh. Loss??? Please calculate yourself!
manowar30 schrieb:Research alone is not enough! Urgent advice: Have the provider prepare a final energy consumption forecast based on the actual parameters before signing the contract.
After researching the efficiency classes and energy demand of our future house, I still have a few questions.
manowar30 schrieb:This example clearly shows that neither an MEP engineer nor a specialized energy consultant took the lead. The overall concept is hardly profitable. Probably a standard turnkey/general contractor offer! ;-)
...Where can I get calculations whether this will be enough for 2 people living in 160 sqm? Both in summer with solar collectors and in winter with the hydronic stove....
manowar30 schrieb:Forum posts cannot replace precise system dimensioning. The risks are considerable!
Or can you tell me if this will be sufficient?
manowar3024 Jun 2011 20:53We have neither requested a quote nor consulted with experts.
Construction will likely start around early next year or the year after.
We are in no rush since we currently don’t pay any rent anyway....
I just wanted, as a layperson, to find out what people in this forum think of my concept. I figured it out myself and just wanted to know if it’s enough to manage without gas or oil heating...
Regards
joe
Regards
joe
