SvenRoob-130 Aug 2012 19:34In our new build, we have a serious mold problem in the concrete basement. Despite regular ventilation, it just doesn’t get any drier. Does anyone have a good recommendation for a reliable ventilation or drying device for the basement? I want to finally solve this issue because in its current state, the basement is unusable.
MODERATOR1 Sep 2012 00:09It seems like moisture is repeatedly coming in.
Was your basement constructed using so-called waterproof concrete (WU concrete)? There are several mistakes that can be made with this, which can lead to an unexpectedly high level of moisture.
Otherwise, there are likely areas in the basement exterior walls that are permeable to water and need to be identified and sealed.
In any case, a damp and moldy basement is considered defective.
Ricardo-118 Aug 2014 12:48I know this from my neighbor, and his basement is always damp as well. He complained about it, but at first, no one paid any attention. Only after he threatened to involve a lawyer was an expert brought in. The expert then identified the cause.
herrmann-118 Oct 2014 04:35The first question is where the moisture in the basement is coming from. I assume it is not caused by water damage, and this needs to be determined. This can be a very complex process. A drying device can help to some extent initially. If the source is not found on your own, then hire a professional, as they have experience with this.
A damp basement is, in my opinion, a major problem. Mold can spread extensively and cause a lot of damage. If the cause is not identified and fixed, a dehumidifier will end up consuming a lot of electricity.
Often, the moisture develops beneath the screed, which is usually not visible because nobody wants to break tiles. However, there will probably be no other option.
