ᐅ Vapor Barrier in the Basement – Is There Moisture Beneath?
Created on: 25 Jun 2018 06:21
BenutzerPC
BenutzerPC
25 Jun 2018 06:21
In our basement, a membrane (vapor barrier) was installed during the shell construction phase. However, a hole still had to be drilled to lay the multi-utility cables in the basement. Water was used during the drilling process (presumably to cool the drill). At the same time, plumbing pipes were already laid and secured on top of the membrane. My question is: The area under the membrane is now damp. Is this a problem, or should it be allowed to dry first? This situation is a bit difficult since the membrane can no longer be easily removed due to the pipes already being installed on it.
Is the moisture going to cause any issues later on (like mold), or can the screed be poured over it as is?
Knallkörper
25 Jun 2018 20:19
What kind of membrane is that? I assume the membrane is laid on the base slab and the drilling was done in the wall?
