ᐅ Upgrading underfloor heating with actuators and wireless receivers
Created on: 1 Oct 2020 11:58
ashley
ashley
1 Oct 2020 11:58
Hello, I would like to equip our underfloor heating system with actuators and wireless receivers so that the temperature in the rooms can be controlled using wireless room thermostats. First, a basic question: does the heating manifold also need to be equipped with flow meters for this purpose? Our existing one does not have these meters. A second question: when replacing the actuators, can the old ones simply be removed and the new ones screwed on, or will water leak during this process? Thanks and best regards, Ashley
ashley
1 Oct 2020 12:13
Small white plastic part next to a ribbed rotary knob with arrow direction on wood.
Here is a photo of the current actuator.
U
user-d29
1 Oct 2020 12:38
ashley schrieb:
I want to equip our underfloor heating system with actuators and wireless receivers so that the temperature in the rooms can be controlled using wireless room thermostats.
You don’t control underfloor heating—you set it up properly. After that, you could even remove the thermostats. Anything else is just (financial) nonsense.
Mycraft1 Oct 2020 12:53
That is basically correct, but only if the other parameters are also appropriate.
There are many types of underfloor heating as well as many types of heat sources for them. Therefore, control and regulation can be necessary and useful, for example, in existing buildings with relatively high heat losses, or with fast-responding underfloor heating systems.
ashley
1 Oct 2020 20:14
Mycraft schrieb:
That is basically correct, but only if the other parameters are right as well.
I agree completely. Does anyone possibly have a tip for me?
T_im_Norden
1 Oct 2020 20:47
Without further details about the type of underfloor heating, it is difficult to provide a specific comment. However, as a general rule, any kind of thermostat control for underfloor heating tends to be counterproductive.
