ᐅ TV mounted below the window sill
Created on: 28 Jul 2019 11:45
Andre77
does anyone happen to have their TV positioned under a band of windows and could share a few pictures with me?
If you had to choose, TV under the band of windows, couch opposite, allowing a view through the patio door on the same side as the TV
or
couch under the band of windows (with the garden behind, patio door basically on the couch wall, and the view then towards the opposite wall with the band of windows.
Does anyone have either of these setups?
Thanks and best regards
kbt09
28 Jul 2019 15:02
In that case, I would install a proper window instead of a window strip. Otherwise, the corner around the sofa will really feel like a basement.
Andre77
28 Jul 2019 15:51
@kbt09
If the window band were actually quite small, something like 50 cm (20 inches) wide, then I would agree with your basement idea. As it is, I just can't quite follow. It is as wide as the patio door and 60 cm (24 inches) high. I don't imagine it being that dark. However, a change is no longer possible anyway.
11ant28 Jul 2019 16:24
Andre77 schrieb:
If the window band were actually quite small, something like 50cm (20 inches) wide, then it would be
... a joke to call it a window band
kbt09
28 Jul 2019 16:27
It is the parapet height of 175 cm (finished floor level probably closer to 160 cm (63 inches)), that creates the basement feel. Have you seen it in person? Also, a clear opening height of 60 cm (24 inches) will likely result in a glass area only about 45 cm (18 inches) high. Yes, some light comes in, but you won’t be able to see out properly with a window like that.
Andre77
28 Jul 2019 16:28
... it’s a joke to call that a ribbon window
Exactly, because then it would have to be called a basement window
Andre77
28 Jul 2019 16:31
kbt09 schrieb:
Yes, some light comes in, but you can’t really see through a window like that.
Um, it’s not meant to look out either, and above all, not to look in...
