ᐅ Topcoat plaster is slipping (not setting properly) – what is an appropriate retention amount, approximately?
Created on: 5 Dec 2012 13:42
Dee
Dee
5 Dec 2012 13:42
Hello!
The work on my little house is coming to an end, but unfortunately last week, during continuous heavy rain, the topcoat on one gable facade started to detach in several strips and slipped off.
Construction: base coat and topcoat on aerated concrete blocks.
Base coat: mineral fiber lightweight render, topcoat: silicone resin render.
The builder intends to record the damaged render as a defect during the upcoming house handover and plans to re-plaster the entire gable wall next spring (removing the topcoat).
How much should my retention (deduction from the corresponding payment) be?
The payment for plastering (base coat and topcoat) is 7,000 EUR.
Re-plastering is required for the ground floor and the gable (one facade).
Gross surface area approx. 50 sqm (538 sq ft), 4 windows + 1 door.
What would be a reasonable retention? 2,000 EUR? Less?
I would appreciate an estimate.
Regards,
Dee
Wastl
5 Dec 2012 14:08
We withheld €2,000 (materials are already on site) for one-third of the wall area, approximately 90 m² (970 ft²).
Boergi
5 Dec 2012 14:14
Do you have a contract according to VOB?
You can claim double the costs for rectifying the defects.
I would calculate the total amount per square meter based on the damaged square meters, plus the cost for removing the existing plaster, and then multiply the whole by two.
Regards,
Sebastian
Dee
5 Dec 2012 14:17
No, the Building Code.
Can I also charge double the costs there?
Regards
Dee
Dee
11 Dec 2012 19:18
Yes - Section 641 of the Building Code! Regards, Dee :-)
