Erkanovicz18 Mar 2021 11:57Hello everyone,
I have completely renewed the electrical system in the house and now want to work on the satellite system.
My plan is as follows:
Four cables per LNB to the basement
From the basement to the rooms
The satellites to be received are TurkSat, AstraSat, and Thaicom.
From what I have read, TurkSat and AstraSat can apparently be received with one dish and two LNBs.
Is that correct?
What would you recommend for a switch if I have two satellites with three LNBs and want to distribute them inside the house?
Is that correct?
Yes, you can receive Astra (1a?) and Türksat with one dish and two LNBs, but not with a standard dish. You need a multifocus antenna, which has a wider reception range since the two satellites are about 20° apart. Additionally, you will need a 9-way (or 13-way) multiswitch, preferably from Jultec.
Thai is about 40° away and therefore requires its own (large!) dish.
Oh, and please make sure to follow proper grounding and lightning protection, or else @Dipol will be climbing onto your roof.
