ᐅ Thermal Envelope and Partial Basement Insulation: How to Insulate, Experiences?
Created on: 28 Aug 2023 13:11
Proeter
Proeter
28 Aug 2023 13:11
Hello fellow home builders,
In existing houses (especially from the 1970s and 1980s), some basement rooms are often designated and developed as living spaces, for example with large light wells in front of the windows and adequate ceiling height.
How can a partially finished basement be brought up to modern insulation standards? Essentially, the basement living areas would need to be included in the thermal envelope of the living space. This would require these rooms to be insulated separately from the other basement rooms. For the remaining utility basement rooms, the ceiling to the ground floor would then need to be insulated.
I find very little information online about this topic, which actually applies to many existing houses. What is the typical insulation concept for partially finished basements?
11ant28 Aug 2023 14:25
Proeter schrieb:
How can a partially finished basement be upgraded to meet modern insulation standards? Essentially, the basement living areas should be included in the thermal envelope of the living space. However, these areas would then need to be insulated separately from the other basement rooms. In the utility basement rooms, the ceiling to the ground floor would need to be insulated instead.
I find very little information online about this topic, which really affects many existing houses.
... but it also seems to confuse many professionals. In principle, your thinking is correct, but one problem is that the boundaries between living and utility basement rooms do not align with the ceiling sections. As a result, ceiling sections often span across these boundaries. In theory – although the reduction of clear height argues against it – the basement living rooms would also need to be included in the ceiling insulation toward the ground floor to reduce the impracticality of implementing this theory.
28 Aug 2023 22:24
… just the missing basement floor insulation is already a problem, right?
It’s best not to disturb the topic. Focus on the essentials, namely the living floors, that is important.
…and if one or two rooms in the basement invite you to stay, you don’t need a usage permit / building permit for that 😎
X
xMisterDx
31 Aug 2023 01:21
Alternatively, fully insulate the basement. It’s definitely more comfortable than living in a damp, cold utility basement.
Is insulating the basement floor a problem?
Are all houses built before 2020 now going to be demolished because they can’t be energy renovated due to a lack of extruded polystyrene (XPS) insulation in the ground?
