Hello, I have started documenting the temperatures inside our house. I have attached a link with a table. What do you think about the data? The temperatures have remained fairly consistent under similar weather conditions. Overall, I am quite satisfied with the data. I have not made any changes since the hydraulic balancing.
The bedroom upstairs should be cooler. Can I simply reduce the flow rate there? Is there anything else I should consider given that we have very short loops (starting from 16 meters (52 feet) :/)?
In the last four days, we have ventilated very little because we have a central ventilation system. As a result, there hasn’t been much change in the values. Should I continue documenting and ventilate more aggressively and variably in the coming days to test how the rooms warm up? The heating curve is currently set to 2 out of 10. Does it need adjustment? Link description
Hello everyone. I have now made the initial adjustments. In my opinion, something isn’t right. I have turned the valves in the bedroom and dressing room upstairs a full rotation to the left. I also noticed that none of the manifolds can be turned to the right. In my view, their final position has already been reached. I have attached a picture to illustrate this. You can see that when I turn the control to the left, the entire brass part slightly screws downwards. I cannot turn it to the right to increase the flow because the brass part is already hitting the top stop. I hope you understand what I mean. For example, downstairs, I have noticed that there is hardly any flow in the hallway and utility room. There, the control is below 0.5. I have no idea if these circuits are even still open.
