ᐅ Sliding patio door flush with the floor, barrier-free access… Any practical examples?
Created on: 17 Aug 2015 22:52
Bieber0815
Bieber0815
17 Aug 2015 22:52
Hi, we are planning the terrace to be flush with the top edge of the finished floor. The idea is to install a standard patio door from the window manufacturer and an external drainage channel. There is also the option of a level threshold (almost barrier-free). Unfortunately, I don’t have any detailed product data. The relevant standard is quite strict (a 15cm (6 inches) threshold without drainage, which in my experience is rarely seen in practice).
How have you handled this? What did you decide on and why? How high is any existing threshold? Is the terrace covered? Is there drainage? Photos are welcome.
Legurit
17 Aug 2015 23:04
We have a covered area of 2.2 m (7.2 feet) and are planning to connect the terrace more or less level with a lift-and-slide door. The drainage is exactly what we are currently concerned about. Looking forward to seeing if anyone can share their experience here.
nordanney
17 Aug 2015 23:14
For us, it is also on one level. However, we have a wooden deck directly adjacent, so there are never any issues with water (the gravel base outside is about 25 cm (10 inches) lower than the wooden surface).
EveundGerd18 Aug 2015 00:04
We have two terrace exits built according to DIN standards with a threshold sill. It is similar to a step.
Otherwise, we would have had to use liquid waterproofing and install a drainage channel. We have that at the front door... without a channel... the channel was unstable and did not fully serve its intended purpose, as it became clogged quickly.
I can gladly share pictures tomorrow.
Sebastian79
18 Aug 2015 09:24
A zero-threshold entrance is possible but extremely expensive, meaning you’re looking at about 600–700 euros net per meter with a magnetic threshold. I wouldn’t recommend it because it’s outrageously costly.
We have a 20mm (0.8 inch) threshold at the front door and the two floor-to-ceiling windows – the additional cost is minimal, and the threshold is barely noticeable.
At the windows, a slot drain is installed (or alternatively a wooden terrace that is raised high enough), while at the front door we have a step and do without something like that...
wrobel18 Aug 2015 12:42
Hello
We are also planning to use a 20mm (0.8 inch) threshold on the patio and terrace doors.
The terrace should be as close as possible to the same level as the indoor floor.
A drainage channel is not planned; however, we have a 2.6m (8.5 ft) roof overhang,
and the slab is also the finished floor level.
Olli
