ᐅ Structural engineering for gym equipment on the upper floor
Created on: 9 Feb 2025 15:59
SockeldichtungS
Sockeldichtung9 Feb 2025 15:59Hello,
Is the use of the following exercise equipment uncritical for the structural integrity or the screed with underfloor heating in the upper floor of a timber frame house (built in 2024):
This inquiry is not about the floor covering or noise development.
- Mini trampoline used by an adult weighing 75 kg (165 lbs), the trampoline surface area is approximately 0.7 m2 (7.5 sq ft)
- Spinning bike, total weight of bike and user approximately 160 kg (353 lbs), the area over which the feet of the spinning bike distribute the load is about 0.4 m2 (4.3 sq ft) (1 m (3.3 ft) long, 40 cm (16 inches) wide)
nordanney9 Feb 2025 17:15Have you asked this question somewhere else already? It sounds familiar – you won’t get different answers here.
hanghaus20239 Feb 2025 19:26No benches.
1. The trampoline actually reduces the impact compared to jumping directly on the ground because the force is distributed over a larger area and the springs absorb the shock.
2. The bike spreads the load over 0.4 m2 (4.3 ft2), while a somewhat heavy person standing on one leg only applies pressure on 0.04 m2 (0.43 ft2). This makes the wooden beam ceiling seem quite relaxed.
