ᐅ Solar thermal and/or photovoltaic systems – who has experience?
Created on: 4 Mar 2018 17:03
AnNaHF79
after numerous discussions with different experts, we are now quite confused.
Background:
Our house (basement, ground floor, upper floor with a total living area of 200 m² (2,150 sq ft)) has a shed roof with a 12.5° pitch facing northeast.
The first expert recommended adding a solar thermal system to our air-to-water heat pump; the second considers this completely pointless because, according to him, a) we would constantly have uselessly hot water stored in the buffer tank, and, in the worst case, the roof seals could get damaged, whereas with photovoltaic panels we would be more flexible and could use the energy for heating but also for feeding electricity back into the grid when the buffer is full...
In other words, the second expert predicts constantly unused hot water and significant problems with such systems and recommends photovoltaics instead.
What do you think?
abemann
4 Mar 2018 18:20
And then the architect just died on us ;-)
Is that actually a protected term, or can anyone call themselves that?
toxicmolotof
4 Mar 2018 19:05
Then the architect really messed up. This should have been identified in one of the early phases of service (should/must).
But well, nothing can be changed now. I also find solar panels pointless with an air-to-water heat pump, and with the orientation even more so—as just a token feature.
I would have the entire roof covered with flat photovoltaic panels without storage and calculate whether it makes financial sense. Then consider if the additional cost of mounting systems justifies itself. After that, aesthetics can be debated.
However, I think the mounting systems are not worth it.
AnNaHF79
4 Mar 2018 19:12
Simple question:
What is an LP determination? 😉
Fuchur
4 Mar 2018 21:41
AnNaHF79 schrieb:
What is an LP assessment?
The service phases with the architect.
Whether it is worthwhile can be calculated quite accurately using PVGIS. Just search for it online; there is a map where you enter your location and the roof data. It then calculates the expected yield, which allows you to estimate the payback period.
