ᐅ Smart Home – Sense, Nonsense, Possibilities, Plans, and Projects
Created on: 27 Aug 2017 12:59
Mycraft
Here, as the title suggests, you can discuss freely and as you wish.
Mycraft schrieb:
"No future"
is still missing in that slogan... I’d rather go with Z-Wave, so you don’t have to worry about the company going out of business tomorrow and ending up with a bunch of useless electronics at home...Sounds like a sales slogan for overpriced technology. If protocols are open or devices can be flashed, or if you have other simple IR or 433 MHz receivers, you’re more flexible. My "planned controlled residential ventilation": IR remote. Shutter motor via radio, both connected through a Wi-Fi bridge to flexible systems like, for example, FHEM. There is no need for upfront planning. Everything is and remains flexible.
ntsa86 schrieb:
Briefly off-topic: @HAL06120, which roller shutter wireless system does Siewert install? By the way, I still wouldn’t expect the electrician (still RBE?) from Siewert to handle smart home technology. :-)Really off-topic 😉 The key when building with a general contractor is to only include the necessary services. RBE only provides the wiring for the decentralized controlled residential ventilation system and power to the roller shutter box. Anything potentially smart is probably mostly wireless. Honestly, I don’t feel the urge to make everything smart right now. That would just be a gimmick that would likely see little use. So I prefer to add smart features step by step as needed rather than installing everything from the start without really using it (which has often been the case with other things). However, at first I didn’t realize that the original poster was more focused on promoting KNX rather than gathering opinions as stated in the first post. I only noticed that through the parallel KNX thread and the responses 😉 So I’m stepping out of this discussion.HAL06120 schrieb:
Sounds like a sales pitch for overpriced technology. If protocols are open or devices are flashable – and you have other simple IR or 433MHz receivers – you are more flexible. My “planned controlled residential ventilation”: IR remote control. Shutter motor via radio, both integrated through a WiFi bridge into flexible systems like, for example, FHEM. Nothing needs to be planned in advance. Everything is and remains flexible.
I handle it similarly but, unlike you, I use OpenHAB 2. Currently, I only use it in combination with Z-Wave, which is gaining a lot of traction. Even if it weren’t, with OpenHAB I can control almost anything available on the market… but that also applies to FHEM.
I haven’t looked into Sonoff yet, but I will probably use it as an affordable solution for switches. It will only be used where needed—no annoying cables, high reliability according to reports, and costs almost nothing…
HAL06120 schrieb:
At first, I also didn’t notice that the original poster’s main goal was to promote KNX rather than gather opinions as stated in the first post. I only realized this through the parallel KNX thread and the response 😉 So I’m stepping out of this discussion.
Exactly, that’s why I’m stepping away as well. It’s going to start up with preaching again. No one in the KNX corner is interested in more practical and affordable solutions 😉
OT:
Okay, I’m curious if wireless will work for you. From my own experience as a former tenant at Siewert (semi-detached house Lili-Schultz-Weg ;-)), I can tell you that the Wi-Fi signal didn’t make it through the intermediate floor (because of reinforced concrete). I hope you plan for an access point on each floor. ;-)
Regarding the thread:
In the parallel thread, I already expressed my preference for smart home technology. Well, I’m tech-savvy and probably one of the enthusiasts. Still, I wouldn’t want to miss it anymore.
What has been implemented:
- KNX bus system, 5-core cables to sockets, connection points, and blinds
- KNX used for basic functions (light on/off/dimming, blinds up/down/slats)
- Visualization and logic with Loxone, also functions as KNX-IP gateway
- Weather station RenkForce WH2600
- Shading logic via Loxone (controls roller shutters via KNX)
- Automatic night lighting (dimmed light triggered by motion detectors after a certain time), outdoor lights, etc.
- Video door system (audio to follow)
- Automatic disabling of doorbell when away (dogs ...)
- Disabling the circulation pump when away (whether that makes sense is debatable)
- Storm warnings in smart home app
- Presence detection via UniFi Wi-Fi controller
- Temperature measurement in every room (KNX switches)
- Integration of controlled ventilation system & heat pump (read-only, informational via FHEM)
- Smart metering (e.g., to detect whether washing machine or TV is on -> activation of lighting and shading scenes)
- Voice output via network speakers
- Control of garden lighting, robotic mower via UV in garage
- Presence simulation
