ᐅ Smart Home Roller Shutters / Venetian Blinds with Conventional Electrical Systems
Created on: 11 Oct 2020 13:39
allstar83
we are nearing the completion of the detailed planning phase and the start of construction. I’ve already gone through the whole “I want everything until I want nothing” phase regarding smart home features. By now, I would simply like to be able to operate the roller shutters and blinds via an app.
Here are the requirements:
  • Wired switches
  • Central switch for scenes
  • Control via app / possibly also remotely
  • Wind sensor is not necessary; I would prefer to control that remotely if needed. At work, this is handled with KNX, but it’s rather unsatisfactory (the shutters keep going up and down, etc.)
  • I’m not keen on “old-fashioned” controls like small displays or astro timers
What options are currently under consideration?
So far, it looks like only the Gira System 3000 with a Bluetooth module (remote control would then be difficult) is a candidate, or alternatively adding Shelly or flush-mounted actuators (e.g., Bosch, etc.).
I’ve already read and researched pretty much everything about KNX, Loxone, Hager Easy, Homematic, Somfy radio, Zigbee, Z-Wave, and similar systems. Somehow, I seem to be missing something simple or haven’t yet seen a solution that covers the above requirements.
What else is out there, or what would you recommend? Does anyone know the Gira System 3000?
Thanks very much for your experience and advice!
tomtom7923 Oct 2020 15:23
For example, I linked Google and IFTTT and created scenarios like "Google, open the living room windows."
Brainstorming
24 Oct 2020 20:58
tomtom79 schrieb:
For example, I have connected Google and iftth and created scenarios like Google, open the living room windows
Which central unit/system do you use for your smart home?
fab101
24 Oct 2020 22:28
You might also want to take a look at the "Digitalstrom" system for your application. It uses no radio frequency signals; everything is modulated over the existing standard wiring. It is a bit more expensive but works flawlessly in our case – including smartphone app and more.
tomtom7925 Oct 2020 06:23
The Tahoma Box
Alessandro
30 Oct 2020 07:44
tomtom79 schrieb:
You can check if enocean has something or Somfy directly.
There are different actuators that can do more than just on/off.
For example, I have the infrared heater in the bathroom connected to an enocean actuator. You can then include it in scenes.
Try searching for "Thermokon STC-DO Blind."
That’s the actuator you need.
However, you can only buy this device through trade channels.
DaSch1718 Apr 2021 12:52
Is there no one who has installed the Gira System 3000 and can share their experience? Based on our initial research, it is also our favorite, especially since we prefer the other switches and sockets from Gira as well.
