ᐅ Sink with an integrated rim or raised edge
Created on: 28 Oct 2017 20:09
joerng
joerng
28 Oct 2017 20:09
For our guest bathroom, we have chosen a washbasin with a rim at the back and on the sides to prevent water from flowing directly off. It is the "Keramag Renova Nr. 1 Plan" in the size 60 x 48 cm (24 x 19 inches).
For our main bathroom, we are looking for a similar washbasin, but 90–100 cm (35–39 inches) wide with a continuous rim all around. Although the Renova Nr. 1 is also available in larger sizes, the wider versions simply have a broad rim on the sides for placing items, without increasing the size of the basin itself.
Does anyone have a wide washbasin with a rim where the outside edge is not a wide rim or a large "bulge"?
joerng
DNL
29 Oct 2017 09:29
Take a look at “Catalano washbasin”
Alex85
29 Oct 2017 10:03
I think he means something different. Specifically, the edge facing the wall that is raised, so that any water standing on the basin doesn’t run off at the back. Your two suggestions are exactly the opposite.
Bau-Schmidt
29 Oct 2017 10:17
Sample
White rectangular ceramic bathroom sink with drain hole.
Bullz47
30 Oct 2017 07:34
I think the Villeroy & Boch Legato washbasin might be a good choice for you.
I have it in both 60cm (24 inches) and 80cm (31.5 inches) widths.
Both sizes are recommended. It features a nice design, a wide surrounding rim, and a basin that is proportionate to its size.
White wall-mounted washbasin with chrome faucet and soap dispenser in front of brown tiles.
joerng
30 Oct 2017 23:07
Thank you for your responses!
The back edge towards the wall should be exactly like in the example from Bau-Schmidt. Basically, no water should run directly down the outside. And of course on the sides as well.
So the very "old-fashioned" design of almost all basins from the older construction style.
