ᐅ Shed Roof Canopy Over Balcony!? What Should Be Considered?
Created on: 28 Jun 2016 17:54
fraubauer
fraubauer
28 Jun 2016 17:54
I hope this is the right forum.
My balcony on the upper floor is unfortunately not covered. Above me is a roof terrace, and below me is the ground floor.
The balcony extends 5 x 2 m (16 x 6.5 ft) to the south side and about 2 x 2 m (6.5 x 6.5 ft) to the east side, forming an L-shape.
I want to cover the balcony door on the south side with a type of lean-to roof measuring 3 x 2 m (10 x 6.5 ft).
It would be a simple steel structure with plexiglass panels and a small gutter at the front edge of the balcony (to prevent water from running down to the neighbor). Under the lean-to roof, I would like to hang a sunshade in summer—nothing large. The goal is to protect the balcony door from rain, sun, and snow.
Next to me, I have a neighbor with a similar balcony, but facing southwest. They are also considering making some modifications.
Can someone advise me on what to watch out for?
Should I first consult a metalworker, or contact the local authority about building permit / planning permission requirements? Or should I start with a structural engineer?
My balcony floor is a "light granite slab" that looks like hospital flooring. It doesn’t seem very stable. I might also consider installing a wooden decking surface over it...
The lean-to roof should be attached to the wall around the balcony door and at the front railing.
Who can please give some advice?
Thank you very much
erika
28 Jun 2016 17:57
The homeowners’ association must approve this, as the exterior facade will be altered.
