ᐅ Which roofing material is best for a flat shed roof?
Created on: 18 May 2015 12:47
kernm23
kernm23
18 May 2015 12:47
We are unsure about the roof covering.
What type of roof covering would you recommend for a 10-degree single-pitch roof?
Galvanized sheet metal or trapezoidal metal roofing, or tiled roof?
What are the advantages and disadvantages?
For a tiled roof, only flat tiles (e.g., Tegalit tiles) are an option since these are the only ones we like. Would a waterproof underlayment be mandatory?
There will also be a photovoltaic system installed on the roof.
Alexej
18 May 2015 13:14
Hello kernm23,
I’m also interested in the pros and cons. We are planning a single-pitch roof with a current slope of 7 degrees. At some point, we considered an in-roof photovoltaic system, so I would also like to know the costs, in case anyone has experience with that.
Good luck
Alex
Bauexperte
18 May 2015 17:24
kernm23 schrieb:
We are unsure about the roofing material.
What does your contractor say?
kernm23 schrieb:
Tin-plated sheet metal, trapezoidal sheet roofing, or tile roof?
None of these; if the roof pitch is below 12° (12°), always use bitumen and then slate covering.
kernm23 schrieb:
There will also be a photovoltaic system on the roof.
That is always possible, regardless of the roof pitch.
Regards, Bauexperte
wrobel19 May 2015 10:44
Hello
I am also planning a shed roof with a 5° slope.
Most likely bitumen followed by extensive green roofing.
Olli
Jochen10419 May 2015 10:53
We chose trapezoidal steel sheets for the roof covering of our 6° (6°) mono-pitched roof. I can’t share any experience with them yet since we haven’t moved in, but so far, it is definitely watertight.
kernm23
19 May 2015 15:42
Could you maybe upload a photo? Do you have a photovoltaic system installed on it?
